Tools on surface-24 segment circle
Hi hot blooded sketchuppers.
i have just been using the plugin ' tools on surface'
the circle on surface comes with a default of 24 segments.is there way to raise these 24 segments to higher number.
Create your circle then type 50s and enter, or whatever number you want, S stands for sides [segments].
If there is no preset(I didn't check), you certainly can re-segment by Window>EntityInfo>edit the segment field.
If I get a chance to check it I will edit this reply, unless someone else responds faster.
Best wishes.Edit before final submit: See what I mean?
Hi sketchup73, you can change the preset number of segments (and many other presets) by going to tools-->Fredo6 collection-->Tools on surface-->default parameters.
Then you need to restart Sketchup in order to make that change effective.
