    Challenge Chair
    57 Posts 19 Posters 9.6k Views 19 Watching
      dylan
      jsteacy I think those are fantastic.
      A great advert for Twilight in my opinion.
      Did you use the studio setup or create your own?
      http://dmdarchitecture.co.uk/
      • olisheaO Offline
        olishea
        yeah they are cool! but have you unsoftened the edges of the studio backdrop? should be a smooth surface.
        oli
        • olisheaO Offline
          olishea
          jsteacy: here are some nice models for testing materials.
          deformed sphere model "pollen".
          [images of the model] ----> http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=1231
          download link:
          http://www.box.net/shared/pidnhj8h30
          ant chair composition.
          download link:
          http://www.box.net/shared/yvi1x9174a
          oli
          • massimoM Offline
            massimo Moderator
            A funny plastic material...๐Ÿ˜„
            • michaliszissiouM Offline
              michaliszissiou
              And a beautiful one massimo!
              • massimoM Offline
                massimo Moderator
                Thanks Michalis. ๐Ÿ˜„
                • olisheaO Offline
                  olishea
                  whats the density of it? dont send me the material file, i wanna learn how to achieve the effect!
                  most SSS i see are very dense, dont even look translucent, yours is perfect ๐Ÿ‘
                  oli
                  • marvins_dadM Offline
                    marvins_dad
                    Okay - had to play a little more. I think the top of the chair is looking more and more like Cousin Itt.
                    My Gallery
                      marvins_dad
                      Okay - last one.
                      "Cousin Itt" Chair http://www.google.com/images?hl=en&safe=active&client=firefox-a&hs=rvE&rls=org.mozilla:en-US:official&q=cousin%20itt&um=1&ie=UTF-8&source=og&sa=N&tab=wi&biw=1600&bih=1048
                      My Gallery
                        jsteacy
                        @Dylan - the render is just Olishea's model with an Hdri I downloaded, I can't remember where from though.
                        @Olishea - I didn't modify the model you posted so I don't know how it un-softened that edge like it did....
                        @Massimo - I love the look of those plastic materials.
                        • massimoM Offline
                          massimo Moderator
                          Ok no material file then Oli...But it's quite hard to explain ๐Ÿ˜†
                          The "basic" material is a layered material made as a mix between a dielectric glass and a layered material made with transmitted colour and specular. By changing the percentage of the weights between the two layers as well as by changing the transmitted & specular shininess you can control the "density" of the material. The balance of that one was: dielectric glass--> 0.2 and transmitted + specular--> 0.8. The IOR used is 1.345.![scheme of the structure of the "basic" material](/uploads/imported_attachments/sIgR_schemeofthematerial.JPG "scheme of the structure of the "basic" material")
                          • massimoM Offline
                            massimo Moderator
                            Glad you like it jsteacy ๐Ÿ˜„ .
                            This model is really funny... So here you have a "sculpture chair" ๐Ÿ˜† . An experiment with a material made with a wireframe procedural used as a clipmap.
                            • olisheaO Offline
                              olishea
                              bloody hell!
                              these are getting out of control, thats seriously impressive. thanks for material help by the way, Im trying to learn KT material editor. ๐Ÿ‘ how have you mapped that mesh texture so well?! im proper baffled...or does it "add" material to the lines of the geometry? โ“ ๐Ÿ˜ฒ ๐Ÿ˜ณ
                              "wirefame procedural"? not seen these before ๐Ÿ˜ฎ i guess the clue is in the name!!
                              cousin itt is so funny!!
                              oli
                              • massimoM Offline
                                massimo Moderator
                                No maps at all. ๐Ÿ˜„
                                It's just the mesh of the model... With that procedural you have only to choose on what edges you want to apply it and set the tickness, fadeout etc.. ๐Ÿ˜„
                                • pyrolunaP Offline
                                  pyroluna
                                  Hey Oli why don't you try and sell your chair design to Ikea? Fastest money you've ever made ๐Ÿ˜„
                                    jsteacy
                                    @Olishea - Thanks for the model links, they are great. I attached a quick render of the pollen model. I didn't have the time to let in run for a while but hopefully I will soon. I only got 10 passes on it.
                                    @Massimo - cool wireframe material, I'm curious since twilight can use kerkythea materials if you can use the wireframe material in twilight. That would be really cool. ๐Ÿ˜Ž
                                    jsteacy
                                    Glass render
                                    • EarthMoverE Offline
                                      EarthMover
                                      I thought this would make a cool Wicker chair. Done in Max/Vray. Quadrified the SU mesh with a plugin called Wrapit for Max and then converted the quad edges to a renderable shape (spline). Quick three light studio setup.
                                      Content Creator at Skapeup
                                      • 3 / 3
