    Challenge Chair
    57 Posts 19 Posters 11.9k Views 19 Watching
    • olisheaO Offline
      olishea
      whats the density of it? dont send me the material file, i wanna learn how to achieve the effect!
      most SSS i see are very dense, dont even look translucent, yours is perfect ๐Ÿ‘
      oli
      • marvins_dadM Offline
        marvins_dad
        Okay - had to play a little more. I think the top of the chair is looking more and more like Cousin Itt.
        My Gallery
          marvins_dad
          Okay - last one.
          "Cousin Itt" Chair http://www.google.com/images?hl=en&safe=active&client=firefox-a&hs=rvE&rls=org.mozilla:en-US:official&q=cousin%20itt&um=1&ie=UTF-8&source=og&sa=N&tab=wi&biw=1600&bih=1048
          My Gallery
            jsteacy
            @Dylan - the render is just Olishea's model with an Hdri I downloaded, I can't remember where from though.
            @Olishea - I didn't modify the model you posted so I don't know how it un-softened that edge like it did....
            @Massimo - I love the look of those plastic materials.
            • massimoM Offline
              massimo Moderator
              Ok no material file then Oli...But it's quite hard to explain ๐Ÿ˜†
              The "basic" material is a layered material made as a mix between a dielectric glass and a layered material made with transmitted colour and specular. By changing the percentage of the weights between the two layers as well as by changing the transmitted & specular shininess you can control the "density" of the material. The balance of that one was: dielectric glass--> 0.2 and transmitted + specular--> 0.8. The IOR used is 1.345.![scheme of the structure of the "basic" material](/uploads/imported_attachments/sIgR_schemeofthematerial.JPG "scheme of the structure of the "basic" material")
              • massimoM Offline
                massimo Moderator
                Glad you like it jsteacy ๐Ÿ˜„ .
                This model is really funny... So here you have a "sculpture chair" ๐Ÿ˜† . An experiment with a material made with a wireframe procedural used as a clipmap.
                • olisheaO Offline
                  olishea
                  bloody hell!
                  these are getting out of control, thats seriously impressive. thanks for material help by the way, Im trying to learn KT material editor. ๐Ÿ‘ how have you mapped that mesh texture so well?! im proper baffled...or does it "add" material to the lines of the geometry? โ“ ๐Ÿ˜ฒ ๐Ÿ˜ณ
                  "wirefame procedural"? not seen these before ๐Ÿ˜ฎ i guess the clue is in the name!!
                  cousin itt is so funny!!
                  oli
                  • massimoM Offline
                    massimo Moderator
                    No maps at all. ๐Ÿ˜„
                    It's just the mesh of the model... With that procedural you have only to choose on what edges you want to apply it and set the tickness, fadeout etc.. ๐Ÿ˜„
                    • pyrolunaP Offline
                      pyroluna
                      Hey Oli why don't you try and sell your chair design to Ikea? Fastest money you've ever made ๐Ÿ˜„
                        jsteacy
                        @Olishea - Thanks for the model links, they are great. I attached a quick render of the pollen model. I didn't have the time to let in run for a while but hopefully I will soon. I only got 10 passes on it.
                        @Massimo - cool wireframe material, I'm curious since twilight can use kerkythea materials if you can use the wireframe material in twilight. That would be really cool. ๐Ÿ˜Ž
                        jsteacy
                        Glass render
                        • EarthMoverE Offline
                          EarthMover
                          I thought this would make a cool Wicker chair. Done in Max/Vray. Quadrified the SU mesh with a plugin called Wrapit for Max and then converted the quad edges to a renderable shape (spline). Quick three light studio setup.
                          Content Creator at Skapeup
                          • 3 / 3
