    Drop group or component to surface below?
    23 Posts 10 Posters 10.7k Views 10 Watching
    • JClementsJ Offline
      JClements
      Trying to find a script which I think drops a group or component (or selection?) straight down until it intersects a specific surface below.
      Thanks, John
        autarchos
        try this one:
        (www.smustard.com)
          JClements
          Thank you, Pete.
          This will do the trick.
            Only issue is that the components stop on hidden entities. I have a WIP plugins that fixes that if you run into that problem.
              Also, that plugin will drop (and stop) the components/groups at their origin so on a sloped surface, they will either merge or float. See example below (component axes displayed however faintly they can be seen).
              Another thing is that when undoing, you have to undo them one by one. Nevertheless I keep using it and find it extremely useful when populating terrains with entourage and such. Still I sometimes miss a thing or two as you can see with one of the benches sunk into the ground here (and after hours of rendering). πŸ˜’
                I believe SmartDrop will align the bottom to the surface: http://forums.sketchucation.com/viewtopic.php?f=180&t=3474
                But it also suffers from stopping at hidden entities.
                  Well, nned to check out, thanks.
                  And the credits ("thanks...") also remind me to purchase Tavi's randor (and when I am at it, also his stereo) plugins... πŸ˜’
                    randor and stereo plugins? what's this?
                      randor will randomly scale and rotate objects. Stereo creates two cameras slightly apart from each other so that you can export/render two images and combine them into those 3D images to be watched with those fancy red/green glasses.
                        is randor different from the random scale and rotate plugin Chris got?
                          πŸ˜’
                          I will check.
                            Hm... Even Chris mentions randor here.
                            http://forums.sketchucation.com/viewtopic.php?p=139970#p139970
                            anyway, I have downloaded and will check out...
                              hm.. I've not tried that one. Does it deal with hidden entities?
                              • CadFatherC Offline
                                CadFather
                                yes, it drops the component only to the next visible entity
                                  CadFather
                                  Jim's Mover script drops components pretty well too.. (press CTRL)
                                    Also if the entity itself isn't hidden, but on a hidden layer?
                                      CadFather
                                      no not in that case
                                      • Chris FullmerC Offline
                                        I have been meaning to write a smart drop plugin too that drops to a specified group. I normally want to drop trees down onto a ground plane, and that ground plane is always in a group. So I've meant to write one that will let you select what to drop and then select a group to drop onto. Have not gotten around to it yet though.
                                        And my rotate and scale multiple is essentially the same thing as randor. I was not aiming to re-write that plugin when I started it. I was just supposed to scale multiple components at the same time, based on each one's location. But then it kept evolving and turned into scaling and rotating randomly.
                                        Chris
                                        All my Plugins I've written
                                          Ditto! πŸ˜‰
                                          • onzkiO Offline
                                            onzki
                                            @autarchos said:
                                            try this one:
                                            (www.smustard.com)
                                            Hello everyone! I know this is an old thread, but still in demand feature lol πŸ˜„ .. The link no longer available, anybody knows an alternative? Thanks!
                                            [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                            • 1 / 2
