    Drop group or component to surface below?
    23 Posts 10 Posters 11.1k Views 10 Watching
      is randor different from the random scale and rotate plugin Chris got?
        πŸ˜’
        I will check.
          Hm... Even Chris mentions randor here.
          http://forums.sketchucation.com/viewtopic.php?p=139970#p139970
          anyway, I have downloaded and will check out...
            hm.. I've not tried that one. Does it deal with hidden entities?
            • CadFatherC Offline
              CadFather
              yes, it drops the component only to the next visible entity
                CadFather
                Jim's Mover script drops components pretty well too.. (press CTRL)
                  Also if the entity itself isn't hidden, but on a hidden layer?
                    CadFather
                    no not in that case
                    • Chris FullmerC Offline
                      I have been meaning to write a smart drop plugin too that drops to a specified group. I normally want to drop trees down onto a ground plane, and that ground plane is always in a group. So I've meant to write one that will let you select what to drop and then select a group to drop onto. Have not gotten around to it yet though.
                      And my rotate and scale multiple is essentially the same thing as randor. I was not aiming to re-write that plugin when I started it. I was just supposed to scale multiple components at the same time, based on each one's location. But then it kept evolving and turned into scaling and rotating randomly.
                        Ditto! πŸ˜‰
                        • onzkiO Offline
                          onzki
                          @autarchos said:
                          try this one:
                          (www.smustard.com)
                          Hello everyone! I know this is an old thread, but still in demand feature lol πŸ˜„ .. The link no longer available, anybody knows an alternative? Thanks!
                          [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                            samodelkin_77
                            I`m using Curic Align, its work for any face\edge\middle point
                            Thanks to creature this plugin ))
                            • Didier BurD Offline
                              Didier Bur
                              I don't know if it can help, but take a look at my Components Spray tool:
                              https://extensions.sketchup.com/extension/213a8e60-208f-4b6d-95ff-ab367c09a959/compo-spray
                              Regards,
                              DB
                              • cottyC Offline
                                cotty
                                ThrowTo is another option too...
                                http://sketchucation.com/forums/viewtopic.php?p=465353#p465353
                                my SketchUp gallery
