    Drop group or component to surface below?
    23 Posts 10 Posters 11.0k Views 10 Watching
      randor will randomly scale and rotate objects. Stereo creates two cameras slightly apart from each other so that you can export/render two images and combine them into those 3D images to be watched with those fancy red/green glasses.
        is randor different from the random scale and rotate plugin Chris got?
          πŸ˜’
          I will check.
            Hm... Even Chris mentions randor here.
            http://forums.sketchucation.com/viewtopic.php?p=139970#p139970
            anyway, I have downloaded and will check out...
              hm.. I've not tried that one. Does it deal with hidden entities?
              • CadFatherC Offline
                CadFather
                yes, it drops the component only to the next visible entity
                  CadFather
                  Jim's Mover script drops components pretty well too.. (press CTRL)
                    Also if the entity itself isn't hidden, but on a hidden layer?
                      CadFather
                      no not in that case
                      • Chris FullmerC Offline
                        I have been meaning to write a smart drop plugin too that drops to a specified group. I normally want to drop trees down onto a ground plane, and that ground plane is always in a group. So I've meant to write one that will let you select what to drop and then select a group to drop onto. Have not gotten around to it yet though.
                        And my rotate and scale multiple is essentially the same thing as randor. I was not aiming to re-write that plugin when I started it. I was just supposed to scale multiple components at the same time, based on each one's location. But then it kept evolving and turned into scaling and rotating randomly.
                          Ditto! πŸ˜‰
                          • onzkiO Offline
                            onzki
                            @autarchos said:
                            try this one:
                            (www.smustard.com)
                            Hello everyone! I know this is an old thread, but still in demand feature lol πŸ˜„ .. The link no longer available, anybody knows an alternative? Thanks!
                            [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                              samodelkin_77
                              I`m using Curic Align, its work for any face\edge\middle point
                              Thanks to creature this plugin ))
                              • Didier BurD Offline
                                Didier Bur
                                I don't know if it can help, but take a look at my Components Spray tool:
                                https://extensions.sketchup.com/extension/213a8e60-208f-4b6d-95ff-ab367c09a959/compo-spray
                                Regards,
                                DB
                                • cottyC Offline
                                  cotty
                                  ThrowTo is another option too...
                                  http://sketchucation.com/forums/viewtopic.php?p=465353#p465353
                                  my SketchUp gallery
