    Drop group or component to surface below?
    23 Posts 10 Posters 11.8k Views 10 Watching
    • GaieusG
      Also, that plugin will drop (and stop) the components/groups at their origin so on a sloped surface, they will either merge or float. See example below (component axes displayed however faintly they can be seen).
      Another thing is that when undoing, you have to undo them one by one. Nevertheless I keep using it and find it extremely useful when populating terrains with entourage and such. Still I sometimes miss a thing or two as you can see with one of the benches sunk into the ground here (and after hours of rendering). πŸ˜’
        I believe SmartDrop will align the bottom to the surface: http://forums.sketchucation.com/viewtopic.php?f=180&t=3474
        But it also suffers from stopping at hidden entities.
        • GaieusG
          Well, nned to check out, thanks.
          And the credits ("thanks...") also remind me to purchase Tavi's randor (and when I am at it, also his stereo) plugins... πŸ˜’
            randor and stereo plugins? what's this?
            • GaieusG
              randor will randomly scale and rotate objects. Stereo creates two cameras slightly apart from each other so that you can export/render two images and combine them into those 3D images to be watched with those fancy red/green glasses.
                is randor different from the random scale and rotate plugin Chris got?
                • GaieusG
                  πŸ˜’
                  I will check.
                  • GaieusG
                    Hm... Even Chris mentions randor here.
                    http://forums.sketchucation.com/viewtopic.php?p=139970#p139970
                    anyway, I have downloaded and will check out...
                      hm.. I've not tried that one. Does it deal with hidden entities?
                      • CadFatherC
                        CadFather
                        yes, it drops the component only to the next visible entity
                        • CadFatherC
                          CadFather
                          Jim's Mover script drops components pretty well too.. (press CTRL)
                            Also if the entity itself isn't hidden, but on a hidden layer?
                            • CadFatherC
                              CadFather
                              no not in that case
                              • Chris FullmerC
                                I have been meaning to write a smart drop plugin too that drops to a specified group. I normally want to drop trees down onto a ground plane, and that ground plane is always in a group. So I've meant to write one that will let you select what to drop and then select a group to drop onto. Have not gotten around to it yet though.
                                And my rotate and scale multiple is essentially the same thing as randor. I was not aiming to re-write that plugin when I started it. I was just supposed to scale multiple components at the same time, based on each one's location. But then it kept evolving and turned into scaling and rotating randomly.
                                  Ditto! πŸ˜‰
                                  • onzkiO
                                    onzki
                                    @autarchos said:
                                    try this one:
                                    File Not Found
                                    (www.smustard.com)
                                    Hello everyone! I know this is an old thread, but still in demand feature lol πŸ˜„ .. The link no longer available, anybody knows an alternative? Thanks!
                                    [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                      samodelkin_77
                                      I`m using Curic Align, its work for any face\edge\middle point
                                      Thanks to creature this plugin ))
                                      • Didier BurD
                                        Didier Bur
                                        I don't know if it can help, but take a look at my Components Spray tool:
                                        https://extensions.sketchup.com/extension/213a8e60-208f-4b6d-95ff-ab367c09a959/compo-spray
                                        Regards,
                                        DB
                                        • cottyC
                                          cotty
                                          ThrowTo is another option too...
                                          http://sketchucation.com/forums/viewtopic.php?p=465353#p465353
                                          my SketchUp gallery
