    Extrude Request
    23 Posts 5 Posters 2.0k Views 5 Watching
    • C
      CodyV1
      I never plan to do anything like this, but I have to. Can somebody please extrude this: http://sketchup.google.com/3dwarehouse/details?mid=5f813ac1865b56061c40057691d5a219
      I've extruded almost the entire model, but I just can't do it for this. I've been trying all afternoon. There are directions in the model.
      Be There
      http://www.facebook.com/#!/profile.php?id=100000814922209
        Hi Cody,
        Try these steps and post back with any issues
        Now delete any faces that were created when you used 'Offset' to leave only the path your stand will follow
        Now use the 'Follow Me' tool on your stand
        Here's a little clay render...
        I'd suggest you read up on 'Groups and Components' in the SU Manual it'll help you out alot. Especially the file size πŸ˜‰
        • C
          CodyV1
          Thanks alot for the help so far. But, there's a problem before I start. The track edge consists of many segments instead of just one. I tried welding it, but SketchUp just crashed.
          Be There
            I know, it's a pain in the ass trying to select all those edges manually! but luckily Thom created this little gem.....
            http://forums.sketchucation.com/download/file.php?id=36326
            You can download it here and then float your cursor over the track edge and the whole loop will turn ORANGE then click and it'll select all connect edges! Just make sure you choose the right tool, it's called 'Select Edge Loops'
            Then once selected you can CTRL+ and copy away and run 'Weld' followed by 'Offset'
            • C
              CodyV1
              That link just leads to a picture 😐
              Be There
              • GaieusG
                Selection toys:
                http://forums.sketchucation.com/viewtopic.php?t=14975
                  Sorry Cody
                  Thanks Gaieus πŸ‘
                  • C
                    CodyV1
                    I can't open it in SU. I have both of the files in the Plugins folder
                    Be There
                    • GaieusG
                      What both "files"? They are two zip archives you should unzip straight under the plugins folder (copy all the content from the archives).
                      • C
                        CodyV1
                        I unzipped them using WinRar, then extracted them to the Plugins folder
                        Be There
                        • GaieusG
                          Make sure Windows does NOT make a container folder for them each. All the content must go straight under the plugins folder.
                          • C
                            CodyV1
                            So should I move instead of copy and paste or delete the plugins from My Documents
                            Be There
                            • GaieusG
                              It does not matter - just get the files into the plugins folder somehow.
                              What I mean is that when unzipping a bunch of files, Windows tents to create them a subdirectory. Do not let it do this; move all the contents (subfolders and rb files) straight under Plugins.
                              If it does not work, make a screenshot of your plugins folder and attach here.
                              • thomthomT
                                These are the files and the folder structure that you should have in your plugins folder:
                                • C
                                  CodyV1
                                  I tried taking a screen shot using the default Windows way, but when I go to take it into paint to save it, I get "YOU'VE BEEN HIT WITH THE". So I'm scanning it with McCaffe. But anyway, my plugins folder has the folders thomthom specified.
                                  Be There
                                  • thomthomT
                                    No menus under Tools?
                                    No error messages?
                                    • GaieusG
                                      Forget Windows Paint and similar pains. Get something easy-to-use, free, 3rd party sw like Gadwin PrinScreen or similar.
                                      As for the files being in the right location and STILL not working, I am stumped.
                                      Did you activate the toolbar from View > Toolbars?
                                      • C
                                        CodyV1
                                        It's nice to know even MY technical hickups can blunder even you.
                                        I went through the toolbars and didn't find Toy Selection anywhere.
                                        Be There
                                        • GaieusG
                                          It must be some installation error then. I have Selection Toys (not Toy Selections however) in my toolbar
                                          • thomthomT
                                            Hang on - are we talking about only the item in the Toolbar list?
                                            In Selection Toys you must enable the toolbar under Selection Toy's preferences. This is to prevent Toolbar Shuffle.
                                            You should see a "Selection Toys" menu under Tools and extra context menu items. - Do you see these?
                                            • 1 / 2
