    Extrude Request
    23 Posts 5 Posters 1.2k Views 5 Watching
      I know, it's a pain in the ass trying to select all those edges manually! but luckily Thom created this little gem.....
      http://forums.sketchucation.com/download/file.php?id=36326
      You can download it here and then float your cursor over the track edge and the whole loop will turn ORANGE then click and it'll select all connect edges! Just make sure you choose the right tool, it's called 'Select Edge Loops'
      Then once selected you can CTRL+ and copy away and run 'Weld' followed by 'Offset'
        CodyV1
        That link just leads to a picture 😐
        Be There
        http://www.facebook.com/#!/profile.php?id=100000814922209
          Selection toys:
          http://forums.sketchucation.com/viewtopic.php?t=14975
            Sorry Cody
            Thanks Gaieus πŸ‘
              CodyV1
              I can't open it in SU. I have both of the files in the Plugins folder
              Be There
                What both "files"? They are two zip archives you should unzip straight under the plugins folder (copy all the content from the archives).
                  CodyV1
                  I unzipped them using WinRar, then extracted them to the Plugins folder
                  Be There
                    Make sure Windows does NOT make a container folder for them each. All the content must go straight under the plugins folder.
                      CodyV1
                      So should I move instead of copy and paste or delete the plugins from My Documents
                      Be There
                        It does not matter - just get the files into the plugins folder somehow.
                        What I mean is that when unzipping a bunch of files, Windows tents to create them a subdirectory. Do not let it do this; move all the contents (subfolders and rb files) straight under Plugins.
                        If it does not work, make a screenshot of your plugins folder and attach here.
                          These are the files and the folder structure that you should have in your plugins folder:
                            CodyV1
                            I tried taking a screen shot using the default Windows way, but when I go to take it into paint to save it, I get "YOU'VE BEEN HIT WITH THE". So I'm scanning it with McCaffe. But anyway, my plugins folder has the folders thomthom specified.
                            Be There
                              No menus under Tools?
                              No error messages?
                                Forget Windows Paint and similar pains. Get something easy-to-use, free, 3rd party sw like Gadwin PrinScreen or similar.
                                As for the files being in the right location and STILL not working, I am stumped.
                                Did you activate the toolbar from View > Toolbars?
                                  CodyV1
                                  It's nice to know even MY technical hickups can blunder even you.
                                  I went through the toolbars and didn't find Toy Selection anywhere.
                                  Be There
                                    It must be some installation error then. I have Selection Toys (not Toy Selections however) in my toolbar
                                      Hang on - are we talking about only the item in the Toolbar list?
                                      In Selection Toys you must enable the toolbar under Selection Toy's preferences. This is to prevent Toolbar Shuffle.
                                      You should see a "Selection Toys" menu under Tools and extra context menu items. - Do you see these?
                                      • Jean LemireJ Offline
                                        Jean Lemire
                                        Hi folks.
                                        See this SU file for ideas.
                                        Stadium.zip
                                          CodyV1
                                          No, I don't see it
                                          Be There
                                            CodyV1
                                            Hi Jean,
                                            Thanks for the model, but I'm afraid I've gotten to far in the model to go back and change the seating. I've gotten the seating done by just offsetting the bottom of the racing surface to the back of the building's rim. Plus, I have a road leading in and out of the track area so that cars and other vehicles can enter. I will gladly put you under the contributers for the track when I upload it to the warehouse.
                                            Be There
