    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 125.6k Views 16 Watching
    • simon le bonS Offline
      simon le bon
      OOPs!!! ๐Ÿ˜ณ
      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/oh_shit.jpg
      OF
      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/sudoku-papier-en-action.jpg
      sheet!!! ๐Ÿ˜Ž
      ๐Ÿ˜Ž โ˜€ ๐Ÿ˜Ž ๐Ÿ˜Ž โ˜€ ๐Ÿ˜Ž ๐Ÿ˜†
      The beginning was ''almost'' easy..the next step..i dare to say, it ll be the last ,but good luck anyway!
      I can smell it is the point! Afraid to engage the step ๐Ÿ˜•
      s
      • TaffGochT Offline
        TaffGoch
        @simon le bon said:
        The diamond need to be done with an odd number of semi waves.
        If I take the same wave and use 5 semi waves:
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence007_th.jpg
        that works perfectly.
        Recall that I, also, had a couple of "false starts." You have just re-solved my first false start. ๐Ÿ‘
        My second mistake involved the horizontal "rail" strips that run at the top and bottom of the fence. That spacing also has to be precise, or they won't braid, either.
        (And you can't cheat, by using a different sinusoidal spacing. The fence is supposed to be made of all the same sine-wave wire.) โ˜€
        -Taff
        "Information is not knowledge." -- Albert Einstein
        • TaffGochT Offline
          TaffGoch
          When you have flat model, curved can be made by the Fredo Scale, no? ๐Ÿ˜‰
          That should work fine, for "bending" the top hoops, and the short segments just below the top rails.
          (Pilou, when I first read your post, I wasn't quite sure what you were talking about. Looking back, your idea makes sense, even though I haven't tried it.) ๐Ÿ‘
          -Taff
            And now the coup de grace ๐Ÿ˜‰
            http://clotureslestrie.com/store/images/vinyl_chain_link_roll.jpg
            • TaffGochT Offline
              TaffGoch
              The fence, so far, looks too "wimpy" for my tastes.
              By increasing the amplitude of the sinusoidal paths, and increasing the diameter of the tubular cross-section circle, the fence is no longer made of heavy-gauge wire, but of sturdy wrought iron:
              Wrought iron fencing
              Achieved by editing only the component definitions. No new spacing or sine-wave construction required -- only sine-amplitude scaling, and new "follow me" extrusions, using a larger circle.
              (There are similar wrought-iron fences in New Orleans.)
              Model available in 3D Warehouse:
              Parisian Fence - "Beefier" Version
              Original model:
              Parisian Fence โ€ข Exercise
              -Taff
                simon le bon
                ๐Ÿคฃ
                Sorry Taff to be so slow ๐Ÿ˜•
                (I still haven't opened you skp)
                I have very carefully made a new sinusoid in order to match the 5 semi-waves of the diamond with the picture.
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence009_th.jpg
                I agree with you that the same sine-wave have to be used for the horizontal "rail" strips,
                my mind is the good positioning of them give a starting point for all the geometry.
                I found (evidently) the same results as you
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence010_th.jpg
                Strangely, nothing actually leads me to your intuition of the shared spacing of 6 1/2waves !
                I have next tried to see if:
                The size of angles are significant in structure of the diamond ?
                The answer is Yes and No ๐Ÿ˜†
                The angle of the diamonds on the referential picture, taken by the upper side is about 37ยฐ
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence011_th.jpg
                If I diminish it to 20ยฐ the braiding is still efficient, depending only of the thickness of the string.
                but the point is that then the above horizontal "rail" strip doesn't match anymore at all!!
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence012_th.jpg
                This try leads me to understand that the ideal and true angle for the diamond is 60ยฐ Then the above horizontal "rail" strip match perfectly ๐Ÿ˜Ž
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence013_th.jpg
                Now I am going to see with the curve.
                My Idea is to bend the sinusoid as Pilou's way. I am going to try Chris Fullmer's Shape Bender to establish the curves..
                to be continued..
                ๐Ÿ˜‰ simon
                • TaffGochT Offline
                  TaffGoch
                  Careful, there, Simon... ๐Ÿ˜•
                  ...that was my second mistaken false start! Before I discovered the semi-sinusoidal count, of 6 [NOT 6ยฝ for the horizontal spacing.]
                  -Taff
                  • TaffGochT Offline
                    TaffGoch
                    Simon,
                    You are not the only one to learn by making/correcting mistakes. (The best kind of learning.)
                    I just discovered a spacing mistake I made in the top-rail/hoop area! ๐Ÿ˜ฎ
                    If you're sharp-eyed, you should be able to see the difference between the model I posted here (as an earlier attachment,) and the model I've posted (fixed) at the 3D Warehouse: Parisian Fence โ€ข Exercise
                    http://sketchup.google.com/3dwarehouse/download?mid=1de34a55bdd876622137e32e8ebf2b1&rtyp=lt&ctyp=other&ts=1278298043000
                    -Taff
                      About le "coup de grace", I believe that it will be very easy with Shape Bender by Chris Fullmer ๐Ÿ˜‰
                      • ely862meE Offline
                        ely862me
                        flat coup de grace
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                          simon le bon
                          @Ely!! Hey Guy, I like your way ๐Ÿ‘ ๐Ÿ˜‰
                          @Taff
                          If you're sharp-eyed, you should be able to see the difference ..
                          I don't see ๐Ÿ˜•
                          (I'm very honored you have add this exercise to your Warehouse Collection...)
                          Well I'm glued . May be I haven't the level to solve ๐Ÿ˜•
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence014_th.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence015_th.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence016_th.jpg
                          ๐Ÿ’ญ sim
                          • TaffGochT Offline
                            TaffGoch
                            Simon,
                            You may be stuck (temporarily,) but I am confident, from the quality of the images you've posted, that you have the necessary skills/perception to reproduce the fence geometry.
                            As a physicist, I have faith in "trial and error" experimentation, to solve a problem. You have been demonstrating that you, too, keep experimenting until you find a solution. You are to be commended for not giving up!
                            Spacial perception...
                            (You always have the 3D Warehouse model to which you can refer, if necessary.)
                            -Taff
                            • ely862meE Offline
                              ely862me
                              ๐Ÿ˜„ 2nd step done ๐Ÿ˜„ .. bending was done with Fredo's Radial bending.
                              I did't paid too much attention to the maths(but i made it correctly) and it came out pretty nice.
                              Just need to close the loop and it s done ๐Ÿ˜„ .
                              • TaffGochT Offline
                                TaffGoch
                                I did't paid too much attention to the maths (but i made it correctly) and it came out pretty nice.
                                Just need to close the loop and it's done ๐Ÿ˜„ .
                                Elisei,
                                Looks great!
                                I assume that the sinusoidal segments are still the same length? (It appears so, but I can't tell if they are precisely equal, without measuring.)
                                -Taff
                                • ely862meE Offline
                                  ely862me
                                  Honestly i didn t measure them after bending ๐Ÿ˜• ,and i tend to say they are not even.
                                  Anyway it s finished! Not as perfect as yours but visually almost perfect!
                                  • TaffGochT Offline
                                    TaffGoch
                                    Elisei,
                                    Well, it looks right, and that's what counts. (It is a 3D representation, after all.)
                                    The only difference I can see is more triangulation in the curved hoops, but that's to be expected. I'm sure it was much faster, using Fredo's bending tool, rather than constructing the path, segment-by-segment, as I did.
                                    Nice results! ๐Ÿ‘
                                    -Taff
                                      simon le bon
                                      Hey hey, I'm definitely too slow for this exercise.
                                      (spading the garden helps to sketch)
                                      Bravo Elysei! you race at the top ๐Ÿ‘
                                      Thank you so much Taff!
                                      Well I take the problem by another end: The heads of diamonds are in place leaded by the two fixed pivots. Then the two 5xsemi-waves are rotated to meet along the center the third fixed pivot!
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence017_th.jpg
                                      Then I draw a Bezier spline curve and arrange the three single semi waves arround their pivots. (that I have previously missed) in order to meet the vertical directions. Then I move verticaly the rails to make them match.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence018_th.jpg
                                      If I don't go faster, It is you who are going to give up ๐Ÿ˜† simon
                                      • ely862meE Offline
                                        ely862me
                                        @Taff Yeah,that was the point,to not kill too many neurons and make it quicker ๐Ÿ˜„ .
                                        I wish i have ur patience and ur knowledge about these kind of stuff.
                                        Thanks for helping us to learn a bit more .
                                        @Simon Thanks for compliments and for bringing this challenge up for us.Btw,u are going in the right direction with this(maybe i was a bit faster but your model will look spotless as Taff's)
                                        Here u go,my geometry imperfection ๐Ÿ˜„Parisian Fence.skp
                                        Live in peace!
                                        • TaffGochT Offline
                                          TaffGoch
                                          Elisei,
                                          I opened your model, and measured the distance between sinsusoidal crests.
                                          Straight or curved, lengths are spot on!
                                          Makes me really admire Fredo's tools, even more than before.
                                          -Taff
                                            simon le bon
                                            Dear Taff and Elisei
                                            I keep going after all: I think I have a good idea for the final curved sinusoid but without help of a bending tool.
                                            The last development leads me to find (as you) the mathematical size of 6 semi-waves diamond's width.
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence018_b_th.jpg
                                            So the Diamond becomes a mathematical object perfectly defined in its own dimensions: 6X width, 5x for the sides.
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence021_th.jpg
                                            We only have to say that SketchUp loose the preciseness to calculte the angle, and don't return two times the same value.
                                            But the preciseness is two point better that what gives the tables of sinus:
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence022_th.jpg
                                            Nasa table of sinus
                                            simon
                                            • 6
                                            • 2 / 6
