    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 133.6k Views 16 Watching
      And now the coup de grace ๐Ÿ˜‰
      http://clotureslestrie.com/store/images/vinyl_chain_link_roll.jpg
      • TaffGochT
        TaffGoch
        ย
        The fence, so far, looks too "wimpy" for my tastes.
        By increasing the amplitude of the sinusoidal paths, and increasing the diameter of the tubular cross-section circle, the fence is no longer made of heavy-gauge wire, but of sturdy wrought iron:
        Wrought iron fencing
        Achieved by editing only the component definitions. No new spacing or sine-wave construction required -- only sine-amplitude scaling, and new "follow me" extrusions, using a larger circle.
        (There are similar wrought-iron fences in New Orleans.)
        Model available in 3D Warehouse:
        Parisian Fence - "Beefier" Version
        Original model:
        Parisian Fence โ€ข Exercise
        -Taff
        "Information is not knowledge." -- Albert Einstein
        • simon le bonS
          simon le bon
          ๐Ÿคฃ
          Sorry Taff to be so slow ๐Ÿ˜•
          (I still haven't opened you skp)
          I have very carefully made a new sinusoid in order to match the 5 semi-waves of the diamond with the picture.
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence009_th.jpg
          I agree with you that the same sine-wave have to be used for the horizontal "rail" strips,
          (And you can't cheat, by using a different sinusoidal spacing. The fence is supposed to be made of all the same sine-wave wire.) โ˜€
          my mind is the good positioning of them give a starting point for all the geometry.
          I found (evidently) the same results as you
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence010_th.jpg
          Strangely, nothing actually leads me to your intuition of the shared spacing of 6 1/2waves !
          I have next tried to see if:
          The size of angles are significant in structure of the diamond ?
          The answer is Yes and No ๐Ÿ˜†
          The angle of the diamonds on the referential picture, taken by the upper side is about 37ยฐ
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence011_th.jpg
          If I diminish it to 20ยฐ the braiding is still efficient, depending only of the thickness of the string.
          but the point is that then the above horizontal "rail" strip doesn't match anymore at all!!
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence012_th.jpg
          This try leads me to understand that the ideal and true angle for the diamond is 60ยฐ Then the above horizontal "rail" strip match perfectly ๐Ÿ˜Ž
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence013_th.jpg
          Now I am going to see with the curve.
          My Idea is to bend the sinusoid as Pilou's way. I am going to try Chris Fullmer's Shape Bender to establish the curves..
          to be continued..
          ๐Ÿ˜‰ simon
          • TaffGochT
            TaffGoch
            Careful, there, Simon... ๐Ÿ˜•
            ...that was my second mistaken false start! Before I discovered the semi-sinusoidal count, of 6 [NOT 6ยฝ for the horizontal spacing.]
            -Taff
            • TaffGochT
              TaffGoch
              ย
              Simon,
              You are not the only one to learn by making/correcting mistakes. (The best kind of learning.)
              I just discovered a spacing mistake I made in the top-rail/hoop area! ๐Ÿ˜ฎ
              If you're sharp-eyed, you should be able to see the difference between the model I posted here (as an earlier attachment,) and the model I've posted (fixed) at the 3D Warehouse: Parisian Fence โ€ข Exercise
              http://sketchup.google.com/3dwarehouse/download?mid=1de34a55bdd876622137e32e8ebf2b1&rtyp=lt&ctyp=other&ts=1278298043000
              -Taff
                About le "coup de grace", I believe that it will be very easy with Shape Bender by Chris Fullmer ๐Ÿ˜‰
                • ely862meE
                  ely862me
                  flat coup de grace
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                  • simon le bonS
                    simon le bon
                    @Ely!! Hey Guy, I like your way ๐Ÿ‘ ๐Ÿ˜‰
                    @Taff
                    @taffgoch said:
                    ย
                    If you're sharp-eyed, you should be able to see the difference ..
                    I don't see ๐Ÿ˜•
                    (I'm very honored you have add this exercise to your Warehouse Collection...)
                    Well I'm glued . May be I haven't the level to solve ๐Ÿ˜•
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence014_th.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence015_th.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence016_th.jpg
                    ๐Ÿ’ญ sim
                    • TaffGochT
                      TaffGoch
                      Simon,
                      You may be stuck (temporarily,) but I am confident, from the quality of the images you've posted, that you have the necessary skills/perception to reproduce the fence geometry.
                      As a physicist, I have faith in "trial and error" experimentation, to solve a problem. You have been demonstrating that you, too, keep experimenting until you find a solution. You are to be commended for not giving up!
                      Spacial perception...
                      (You always have the 3D Warehouse model to which you can refer, if necessary.)
                      -Taff
                      • ely862meE
                        ely862me
                        ๐Ÿ˜„ 2nd step done ๐Ÿ˜„ .. bending was done with Fredo's Radial bending.
                        I did't paid too much attention to the maths(but i made it correctly) and it came out pretty nice.
                        Just need to close the loop and it s done ๐Ÿ˜„ .
                        • TaffGochT
                          TaffGoch
                          I did't paid too much attention to the maths (but i made it correctly) and it came out pretty nice.
                          Just need to close the loop and it's done ๐Ÿ˜„ .
                          Elisei,
                          Looks great!
                          I assume that the sinusoidal segments are still the same length? (It appears so, but I can't tell if they are precisely equal, without measuring.)
                          -Taff
                          • ely862meE
                            ely862me
                            Honestly i didn t measure them after bending ๐Ÿ˜• ,and i tend to say they are not even.
                            Anyway it s finished! Not as perfect as yours but visually almost perfect!
                            • TaffGochT
                              TaffGoch
                              Elisei,
                              Well, it looks right, and that's what counts. (It is a 3D representation, after all.)
                              The only difference I can see is more triangulation in the curved hoops, but that's to be expected. I'm sure it was much faster, using Fredo's bending tool, rather than constructing the path, segment-by-segment, as I did.
                              Nice results! ๐Ÿ‘
                              -Taff
                              • simon le bonS
                                simon le bon
                                Hey hey, I'm definitely too slow for this exercise.
                                (spading the garden helps to sketch)
                                Bravo Elysei! you race at the top ๐Ÿ‘
                                Thank you so much Taff!
                                Well I take the problem by another end: The heads of diamonds are in place leaded by the two fixed pivots. Then the two 5xsemi-waves are rotated to meet along the center the third fixed pivot!
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence017_th.jpg
                                Then I draw a Bezier spline curve and arrange the three single semi waves arround their pivots. (that I have previously missed) in order to meet the vertical directions. Then I move verticaly the rails to make them match.
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence018_th.jpg
                                If I don't go faster, It is you who are going to give up ๐Ÿ˜† simon
                                • ely862meE
                                  ely862me
                                  @Taff Yeah,that was the point,to not kill too many neurons and make it quicker ๐Ÿ˜„ .
                                  I wish i have ur patience and ur knowledge about these kind of stuff.
                                  Thanks for helping us to learn a bit more .
                                  @Simon Thanks for compliments and for bringing this challenge up for us.Btw,u are going in the right direction with this(maybe i was a bit faster but your model will look spotless as Taff's)
                                  Here u go,my geometry imperfection ๐Ÿ˜„Parisian Fence.skp
                                  Live in peace!
                                  • TaffGochT
                                    TaffGoch
                                    Elisei,
                                    I opened your model, and measured the distance between sinsusoidal crests.
                                    Straight or curved, lengths are spot on!
                                    Makes me really admire Fredo's tools, even more than before.
                                    -Taff
                                    • simon le bonS
                                      simon le bon
                                      Dear Taff and Elisei
                                      I keep going after all: I think I have a good idea for the final curved sinusoid but without help of a bending tool.
                                      The last development leads me to find (as you) the mathematical size of 6 semi-waves diamond's width.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence018_b_th.jpg
                                      So the Diamond becomes a mathematical object perfectly defined in its own dimensions: 6X width, 5x for the sides.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence021_th.jpg
                                      We only have to say that SketchUp loose the preciseness to calculte the angle, and don't return two times the same value.
                                      But the preciseness is two point better that what gives the tables of sinus:
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence022_th.jpg
                                      Nasa table of sinus
                                      simon
                                        It's maybe not a good idea to use the Shape Bender for a long parisian fence roll!
                                        Better is make a texture from an image result! ๐Ÿ˜‰
                                        (and if it's Nasa who give Sinus'waves that will be even more precise ๐Ÿ’š
                                        • TaffGochT
                                          TaffGoch
                                          @simon le bon said:
                                          "I think I have a good idea for the final curved sinusoid but without help of a bending tool."
                                          While I didn't use it, half of an ellipse looks pretty good:
                                          Half ellipse
                                          @simon le bon said:
                                          "We only have to say that SketchUp loose the preciseness to calculte the angle", and don't return two times the same value.
                                          I reliably & repeatedly get 73.740ยฐ, when using SketchUp's protractor:
                                          Angle
                                          You may need to change your angular settings, in the "Model Info > Units" dialog. (Turn off snapping, and change the precision.)
                                          -Taff
                                          • simon le bonS
                                            simon le bon
                                            Dear Taff,
                                            Sorry again for the time.
                                            The main work which consuming time is to report: prepare Su, take snapshots, comment them, make thumbnails, upload,,
                                            Also I'm not a very brilliant student: which is a good thing to show all the difficulties we have to pass over ๐Ÿ˜‰
                                            I am stucked again.
                                            As we havn't in Su a Bezier curve tool which is able to deal a curve of defined number and length of segments between two fixed points,
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Rope01.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Rope02.jpg
                                            %(#FF0000)[I am actually not able to draw the curve needed.!! โ“ ๐Ÿ’ญ ๐Ÿ’š stupid isn't it ๐Ÿ˜Ž]
                                            (I had first tried to bend (fredoscale) a line exactly segmented and welded as a curve, using a classic bezier curve as a leading shape. but this bending operation had made the segments length changing .)
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence023_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence024_th.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence025_th.jpg
                                            Please Taff, Can you give your solution!!??
                                            Now for the angle of the diamond and the ability of SketchUp into such a preciseness, it seems that I
                                            that was done
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/modele.jpg
                                            have done something wrong โ“
                                            First I have taken your angle of 73,740ยฐ to verify -> ok!
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence026_th.jpg
                                            Second, I have made the construction again, and I find pretty the same as yours.
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence027_th.jpg
                                            *s
                                            • 2 / 6
