    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 133.6k Views 16 Watching
    • TaffGochT
      TaffGoch
      When you have flat model, curved can be made by the Fredo Scale, no? 😉
      That should work fine, for "bending" the top hoops, and the short segments just below the top rails.
      (Pilou, when I first read your post, I wasn't quite sure what you were talking about. Looking back, your idea makes sense, even though I haven't tried it.) 👍
      -Taff
      "Information is not knowledge." -- Albert Einstein
        And now the coup de grace 😉
        http://clotureslestrie.com/store/images/vinyl_chain_link_roll.jpg
        • TaffGochT
          TaffGoch
          The fence, so far, looks too "wimpy" for my tastes.
          By increasing the amplitude of the sinusoidal paths, and increasing the diameter of the tubular cross-section circle, the fence is no longer made of heavy-gauge wire, but of sturdy wrought iron:
          Wrought iron fencing
          Achieved by editing only the component definitions. No new spacing or sine-wave construction required -- only sine-amplitude scaling, and new "follow me" extrusions, using a larger circle.
          (There are similar wrought-iron fences in New Orleans.)
          Model available in 3D Warehouse:
          Parisian Fence - "Beefier" Version
          Original model:
          Parisian Fence • Exercise
          -Taff
          • simon le bonS
            simon le bon
            Sorry Taff to be so slow 😕
            (I still haven't opened you skp)
            I have very carefully made a new sinusoid in order to match the 5 semi-waves of the diamond with the picture.
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence009_th.jpg
            I agree with you that the same sine-wave have to be used for the horizontal "rail" strips,
            (And you can't cheat, by using a different sinusoidal spacing. The fence is supposed to be made of all the same sine-wave wire.) ☀
            my mind is the good positioning of them give a starting point for all the geometry.
            I found (evidently) the same results as you
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence010_th.jpg
            Strangely, nothing actually leads me to your intuition of the shared spacing of 6 1/2waves !
            I have next tried to see if:
            The size of angles are significant in structure of the diamond ?
            The answer is Yes and No 😆
            The angle of the diamonds on the referential picture, taken by the upper side is about 37°
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence011_th.jpg
            If I diminish it to 20° the braiding is still efficient, depending only of the thickness of the string.
            but the point is that then the above horizontal "rail" strip doesn't match anymore at all!!
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence012_th.jpg
            This try leads me to understand that the ideal and true angle for the diamond is 60° Then the above horizontal "rail" strip match perfectly 😎
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence013_th.jpg
            Now I am going to see with the curve.
            My Idea is to bend the sinusoid as Pilou's way. I am going to try Chris Fullmer's Shape Bender to establish the curves..
            to be continued..
            😉 simon
            • TaffGochT
              TaffGoch
              Careful, there, Simon... 😕
              ...that was my second mistaken false start! Before I discovered the semi-sinusoidal count, of 6 [NOT 6½ for the horizontal spacing.]
              -Taff
              • TaffGochT
                TaffGoch
                Simon,
                You are not the only one to learn by making/correcting mistakes. (The best kind of learning.)
                I just discovered a spacing mistake I made in the top-rail/hoop area! 😮
                If you're sharp-eyed, you should be able to see the difference between the model I posted here (as an earlier attachment,) and the model I've posted (fixed) at the 3D Warehouse: Parisian Fence • Exercise
                http://sketchup.google.com/3dwarehouse/download?mid=1de34a55bdd876622137e32e8ebf2b1&rtyp=lt&ctyp=other&ts=1278298043000
                -Taff
                  About le "coup de grace", I believe that it will be very easy with Shape Bender by Chris Fullmer 😉
                  • ely862meE
                    ely862me
                    flat coup de grace
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • simon le bonS
                      simon le bon
                      @Ely!! Hey Guy, I like your way 👍 😉
                      @Taff
                      If you're sharp-eyed, you should be able to see the difference ..
                      I don't see 😕
                      (I'm very honored you have add this exercise to your Warehouse Collection...)
                      Well I'm glued . May be I haven't the level to solve 😕
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence014_th.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence015_th.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence016_th.jpg
                      💭 sim
                      • TaffGochT
                        TaffGoch
                        Simon,
                        You may be stuck (temporarily,) but I am confident, from the quality of the images you've posted, that you have the necessary skills/perception to reproduce the fence geometry.
                        As a physicist, I have faith in "trial and error" experimentation, to solve a problem. You have been demonstrating that you, too, keep experimenting until you find a solution. You are to be commended for not giving up!
                        Spacial perception...
                        (You always have the 3D Warehouse model to which you can refer, if necessary.)
                        -Taff
                        • ely862meE
                          ely862me
                          😄 2nd step done 😄 .. bending was done with Fredo's Radial bending.
                          I did't paid too much attention to the maths(but i made it correctly) and it came out pretty nice.
                          Just need to close the loop and it s done 😄 .
                          • TaffGochT
                            TaffGoch
                            I did't paid too much attention to the maths (but i made it correctly) and it came out pretty nice.
                            Just need to close the loop and it's done 😄 .
                            Elisei,
                            Looks great!
                            I assume that the sinusoidal segments are still the same length? (It appears so, but I can't tell if they are precisely equal, without measuring.)
                            -Taff
                            • ely862meE
                              ely862me
                              Honestly i didn t measure them after bending 😕 ,and i tend to say they are not even.
                              Anyway it s finished! Not as perfect as yours but visually almost perfect!
                              • TaffGochT
                                TaffGoch
                                Elisei,
                                Well, it looks right, and that's what counts. (It is a 3D representation, after all.)
                                The only difference I can see is more triangulation in the curved hoops, but that's to be expected. I'm sure it was much faster, using Fredo's bending tool, rather than constructing the path, segment-by-segment, as I did.
                                Nice results! 👍
                                -Taff
                                • simon le bonS
                                  simon le bon
                                  Hey hey, I'm definitely too slow for this exercise.
                                  (spading the garden helps to sketch)
                                  Bravo Elysei! you race at the top 👍
                                  Thank you so much Taff!
                                  Well I take the problem by another end: The heads of diamonds are in place leaded by the two fixed pivots. Then the two 5xsemi-waves are rotated to meet along the center the third fixed pivot!
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence017_th.jpg
                                  Then I draw a Bezier spline curve and arrange the three single semi waves arround their pivots. (that I have previously missed) in order to meet the vertical directions. Then I move verticaly the rails to make them match.
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence018_th.jpg
                                  If I don't go faster, It is you who are going to give up 😆 simon
                                  • ely862meE
                                    ely862me
                                    @Taff Yeah,that was the point,to not kill too many neurons and make it quicker 😄 .
                                    I wish i have ur patience and ur knowledge about these kind of stuff.
                                    Thanks for helping us to learn a bit more .
                                    @Simon Thanks for compliments and for bringing this challenge up for us.Btw,u are going in the right direction with this(maybe i was a bit faster but your model will look spotless as Taff's)
                                    Here u go,my geometry imperfection 😄Parisian Fence.skp
                                    Live in peace!
                                    • TaffGochT
                                      TaffGoch
                                      Elisei,
                                      I opened your model, and measured the distance between sinsusoidal crests.
                                      Straight or curved, lengths are spot on!
                                      Makes me really admire Fredo's tools, even more than before.
                                      -Taff
                                      • simon le bonS
                                        simon le bon
                                        Dear Taff and Elisei
                                        I keep going after all: I think I have a good idea for the final curved sinusoid but without help of a bending tool.
                                        The last development leads me to find (as you) the mathematical size of 6 semi-waves diamond's width.
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence018_b_th.jpg
                                        So the Diamond becomes a mathematical object perfectly defined in its own dimensions: 6X width, 5x for the sides.
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence021_th.jpg
                                        We only have to say that SketchUp loose the preciseness to calculte the angle, and don't return two times the same value.
                                        But the preciseness is two point better that what gives the tables of sinus:
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence022_th.jpg
                                        Nasa table of sinus
                                        simon
                                          It's maybe not a good idea to use the Shape Bender for a long parisian fence roll!
                                          Better is make a texture from an image result! 😉
                                          (and if it's Nasa who give Sinus'waves that will be even more precise 💚
                                          • TaffGochT
                                            TaffGoch
                                            @simon le bon said:
                                            "I think I have a good idea for the final curved sinusoid but without help of a bending tool."
                                            While I didn't use it, half of an ellipse looks pretty good:
                                            Half ellipse
                                            @simon le bon said:
                                            "We only have to say that SketchUp loose the preciseness to calculte the angle", and don't return two times the same value.
                                            I reliably & repeatedly get 73.740°, when using SketchUp's protractor:
                                            Angle
                                            You may need to change your angular settings, in the "Model Info > Units" dialog. (Turn off snapping, and change the precision.)
                                            -Taff
                                            • 2 / 6
