    An exercise: DRAWING A PARISIAN FENCE
    115 Posts 16 Posters 133.6k Views 16 Watching
    • simon le bonS
      simon le bon
      Dear Taff,
      I go slow, step by step. It is so cool to get you as professor ๐Ÿ‘
      1)how to make a sine-wave.
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence001_th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence002_th.jpg
      2)anatomy of the braided fence
      Re I see 6 but not 5 1/2 sine-waves:?: โ“
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence003_th.jpg
      OK we'll see later!
      3)some testing just to see!
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence003_b_th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence004_th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence006_th.jpg
      ..to be continued
      ๐Ÿ˜‰ simon
      • simon le bonS
        simon le bon
        @ely862me said:
        Mr Simon,watch it, because they are now weaving.
        ๐Ÿ˜ณ Ely, I don't understand what that means..
        Well: there is a problem with my previous test.
        If I use 6 by 6 half waves as shown, the wiring doesn't braid!!!
        let me see...
        *s
        • ely862meE
          ely862me
          Edited:Mr Simon,watch it, because they are NOT weaving(braiding). (sorry ๐Ÿ˜ณ not so usual words for me ๐Ÿ˜„ )
          Elisei (sketchupper)
          Come and See EliseiDesign
          • ely862meE
            ely862me
            I meant it s not braiding.
            U must follow the indication from Taff : 5 by 6(diagonal)
            • simon le bonS
              simon le bon
              Taff, you are right!
              And Ely too (you are quicker than me ๐Ÿ˜† )
              The diamond need to be done with an odd number of semi waves.
              If I take the same wave and use 5 semi waves:
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence007_th.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence008_th.jpg
              that works perfectly.
              if I analyze better the fence -( I take a pen an a shit of paper ๐Ÿ˜‰ and draw the wave blindely, just looking to the picture, i discover you are right: 5x5 semi waves!)
              A good point
              going to next step..
              simon
                shit of paper
                ๐Ÿ˜ฒ
                Otherwise an excellent study to compliment Taff's Geodesic Challenge.
                Look forward to the 'Loop' mathematics ๐Ÿ˜‰
                Rich
                • ely862meE
                  ely862me
                  The beginning was ''almost'' easy..the next step..i dare to say, it ll be the last ๐Ÿ˜† ,but good luck anyway!
                  • ely862meE
                    ely862me
                    shit of paper
                    ๐Ÿ˜ฒ
                    ๐Ÿ˜† ๐Ÿ˜†
                    • simon le bonS
                      simon le bon
                      OOPs!!! ๐Ÿ˜ณ
                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/oh_shit.jpg
                      OF
                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/sudoku-papier-en-action.jpg
                      sheet!!! ๐Ÿ˜Ž
                      ๐Ÿ˜Ž โ˜€ ๐Ÿ˜Ž ๐Ÿ˜Ž โ˜€ ๐Ÿ˜Ž ๐Ÿ˜†
                      The beginning was ''almost'' easy..the next step..i dare to say, it ll be the last ,but good luck anyway!
                      I can smell it is the point! Afraid to engage the step ๐Ÿ˜•
                      s
                      • TaffGochT
                        TaffGoch
                        Recall that I, also, had a couple of "false starts." You have just re-solved my first false start. ๐Ÿ‘
                        My second mistake involved the horizontal "rail" strips that run at the top and bottom of the fence. That spacing also has to be precise, or they won't braid, either.
                        (And you can't cheat, by using a different sinusoidal spacing. The fence is supposed to be made of all the same sine-wave wire.) โ˜€
                        -Taff
                        "Information is not knowledge." -- Albert Einstein
                        • TaffGochT
                          TaffGoch
                          When you have flat model, curved can be made by the Fredo Scale, no? ๐Ÿ˜‰
                          That should work fine, for "bending" the top hoops, and the short segments just below the top rails.
                          (Pilou, when I first read your post, I wasn't quite sure what you were talking about. Looking back, your idea makes sense, even though I haven't tried it.) ๐Ÿ‘
                          -Taff
                            And now the coup de grace ๐Ÿ˜‰
                            http://clotureslestrie.com/store/images/vinyl_chain_link_roll.jpg
                            • TaffGochT
                              TaffGoch
                              ย
                              The fence, so far, looks too "wimpy" for my tastes.
                              By increasing the amplitude of the sinusoidal paths, and increasing the diameter of the tubular cross-section circle, the fence is no longer made of heavy-gauge wire, but of sturdy wrought iron:
                              Wrought iron fencing
                              Achieved by editing only the component definitions. No new spacing or sine-wave construction required -- only sine-amplitude scaling, and new "follow me" extrusions, using a larger circle.
                              (There are similar wrought-iron fences in New Orleans.)
                              Model available in 3D Warehouse:
                              Parisian Fence - "Beefier" Version
                              Original model:
                              Parisian Fence โ€ข Exercise
                              -Taff
                              • simon le bonS
                                simon le bon
                                ๐Ÿคฃ
                                Sorry Taff to be so slow ๐Ÿ˜•
                                (I still haven't opened you skp)
                                I have very carefully made a new sinusoid in order to match the 5 semi-waves of the diamond with the picture.
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence009_th.jpg
                                I agree with you that the same sine-wave have to be used for the horizontal "rail" strips,
                                my mind is the good positioning of them give a starting point for all the geometry.
                                I found (evidently) the same results as you
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence010_th.jpg
                                Strangely, nothing actually leads me to your intuition of the shared spacing of 6 1/2waves !
                                I have next tried to see if:
                                The size of angles are significant in structure of the diamond ?
                                The answer is Yes and No ๐Ÿ˜†
                                The angle of the diamonds on the referential picture, taken by the upper side is about 37ยฐ
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence011_th.jpg
                                If I diminish it to 20ยฐ the braiding is still efficient, depending only of the thickness of the string.
                                but the point is that then the above horizontal "rail" strip doesn't match anymore at all!!
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence012_th.jpg
                                This try leads me to understand that the ideal and true angle for the diamond is 60ยฐ Then the above horizontal "rail" strip match perfectly ๐Ÿ˜Ž
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence013_th.jpg
                                Now I am going to see with the curve.
                                My Idea is to bend the sinusoid as Pilou's way. I am going to try Chris Fullmer's Shape Bender to establish the curves..
                                to be continued..
                                ๐Ÿ˜‰ simon
                                • TaffGochT
                                  TaffGoch
                                  Careful, there, Simon... ๐Ÿ˜•
                                  ...that was my second mistaken false start! Before I discovered the semi-sinusoidal count, of 6 [NOT 6ยฝ for the horizontal spacing.]
                                  -Taff
                                  • TaffGochT
                                    TaffGoch
                                    ย
                                    Simon,
                                    You are not the only one to learn by making/correcting mistakes. (The best kind of learning.)
                                    I just discovered a spacing mistake I made in the top-rail/hoop area! ๐Ÿ˜ฎ
                                    If you're sharp-eyed, you should be able to see the difference between the model I posted here (as an earlier attachment,) and the model I've posted (fixed) at the 3D Warehouse: Parisian Fence โ€ข Exercise
                                    http://sketchup.google.com/3dwarehouse/download?mid=1de34a55bdd876622137e32e8ebf2b1&rtyp=lt&ctyp=other&ts=1278298043000
                                    -Taff
                                      About le "coup de grace", I believe that it will be very easy with Shape Bender by Chris Fullmer ๐Ÿ˜‰
                                      • ely862meE
                                        ely862me
                                        flat coup de grace
                                        • simon le bonS
                                          simon le bon
                                          @Ely!! Hey Guy, I like your way ๐Ÿ‘ ๐Ÿ˜‰
                                          @Taff
                                          @taffgoch said:
                                          ย
                                          If you're sharp-eyed, you should be able to see the difference ..
                                          I don't see ๐Ÿ˜•
                                          (I'm very honored you have add this exercise to your Warehouse Collection...)
                                          Well I'm glued . May be I haven't the level to solve ๐Ÿ˜•
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence014_th.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence015_th.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ParisianFence016_th.jpg
                                          ๐Ÿ’ญ sim
                                          • TaffGochT
                                            TaffGoch
                                            Simon,
                                            You may be stuck (temporarily,) but I am confident, from the quality of the images you've posted, that you have the necessary skills/perception to reproduce the fence geometry.
                                            As a physicist, I have faith in "trial and error" experimentation, to solve a problem. You have been demonstrating that you, too, keep experimenting until you find a solution. You are to be commended for not giving up!
                                            Spacial perception...
                                            (You always have the 3D Warehouse model to which you can refer, if necessary.)
                                            -Taff
                                            • 2 / 6
