    [Help] Context Menu Greyout from the Start! [SOLVED]
    12 Posts 5 Posters 1.0k Views 5 Watching
      chango70
      This is what I get when I START Sketchup!!!!
      What is going on!?
      Just downloaded loads of plugins with Jim's wonderful list. Does anyone know which ones are the culprit?
        chango70
        It appears as though fredoscale and fredo's ghosted components where the culprits. I removed them and the menu came back...
          As mentioned - you should be able to have Fredo's plugins installed - but you must ensure you have the latest versions.
          • TIGT Online
            Ensure you have Fredo's Lib3.4c and Lib3.5 too........
            You CAN have/use all/any of Fredo's tools without the gray-out problem, IF you have the up to date versions and the correct 'Lib' files/folders...................
              chango70
              I do have both folders.
                chango70
                Just tested lib3.4c and Fredoscale 2.0i
                Definitely causes some context menu grey outs
                Stuff like putoncurrentlayer and Construction grid etc. gets greyed out.
                Hope that is help to someone.
                • fredo6F Offline
                  fredo6
                  I think this is a different case, because the Gray-out syndrom appears right away, not after a while.
                  I had another user signaling it.
                  I need to dig into it. Unfortunately it does not happen on any of my PC configurations. So I would need some users who can reproduce it to cooperate and test some specific updates.
                  Fredo
                    It does look like an extreme number of plugins are installed. Could be that the menu resources are exhausted.
                    @chango70: are there other plugins there you don't really use? If you remove a few of those - does the menus still grey out?
                    • fredo6F Offline
                      fredo6
                      Chango (and those users having an immediate gray-out syndrom)
                      Can you please drop the attached file Lib6Plugin.rb into the LIBFREDO6_Dir_34 directory.
                      I disable the creation of contextual menus.
                      to drop into LIBFREDO6_Dir_34 subfolder
                      As you may have installed Curviloft and now have LibFredo 3.5 active, here is an updated file that you can alternatively dropped into the LIBFREDO6_Dire_35 subfolder
                      This will allow me knowing if the issue comes from the creation of menu entries.
                      Thanks very much
                      Fredo
                      to drop into LIBFREDO6_Dir_35 subfolder
                      • P Offline
                        prismcnd
                        Happened to me as well on my Win 7 64 machine. Am testing new libraries will let you know
                        “Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
                        • P Offline
                          prismcnd
                          Unloaded all my plugins and traced it yo Z_loader for free scale.... back up and running normal. all files have been updated to latest version prior to this. I wish I could give more info but my computer expertise ends there. I usually fix my computer problems with a hammer. Permanently. but seriously, let me know if i can help in any way to track this down as it is very annoying
                            FreeScale is the old version - the new version is now named FredoScale.
