    Make a light bulb?
    8 Posts 6 Posters 1.9k Views 6 Watching
      Jakerlund
      I'm quite new to SU and have searched all over the net for a tutorial on making a classic light bulb but haven't found one.
      So i thought i should ask here πŸ˜‰
      Thanks a lot
      • EscapeArtistE Offline
        EscapeArtist
        How detailed do you need it to be?
        • numbthumbN Offline
          numbthumb
          Hello,
          Any tutorial on using the Follow Me tool would be a good start IMO - like this one http://www.youtube.com/watch?v=MV7GBSPsK04&feature=PlayList&p=276F8BA0F9B624C2&playnext_from=PL&playnext=1&index=13
          Comfortably numb...
            Jakerlund
            The details aren't very important, i just don't know how to make the bulb shape or the screw thing at the bottom. 😳
            • Rich O BrienR Online
              Or you could try one of these and see what was done. Then try to replicate it using numbthumb's suggestion and post back with any questions.
              For then screw try searching the forums for 'How to make a screw thread?'
              • shuraS Offline
                shura
                Hi Jakerlund, welcome to Sketchucation.
                looks like Numb and Rich have beaten me on this - anyway here it goes:
                First of all my recommendation for learning the basics of SketchUp: Check out the video tutorials here http://sketchup.google.com/intl/en/training/videos.html
                Maybe you already know these, but you should take a closer look at the follow-me tool and how to create a sphere or other objects with rotational shape. The only tut with a light bulb that I know of is here : http://www.sketchucation.com/creating-a-designer-lamp-in-google-sketchup/
                ...but this is mostly on making the lampshade...
                You can also take a closer look at the models you can find in 3d-warehouse to find out what they are made of: http://sketchup.google.com/3dwarehouse/search?q=lightbulb&styp=m&btnG=Suchen
                Or just try to retrace what I have put into this screenshot...
                glad if it helps
                alex
                  Jakerlund
                  glad if it helps
                  alex
                  Thank you so much Alex,
                  This was a perfect tutorial!
                  Now i can make a bulb... 😍
                  Last question.... how do i get rid of that line on the lower part of the bulb?
                  If i select the line and delete it opens a rectangular hole in the bulb, can i weld the two surfaces in some way?
                    d12dozr
                    Just soften those lines: Eraser + Control key (or Option key if on Mac)
                    http://goo.gl/f7ooYh
