    Im no noob but this is a chalenge to me...
    5 Posts 3 Posters 1.1k Views 3 Watching
    • K
      Keksschredder
      Hi sketchers, since one picture explains as much as thousand words...here is my chalenge. (.png below)
      I found this picture and its the closest one to my conception. The only thing i want to change is, that the staves should be round. The guy who created this uses ruby. I hope there is a more simple way to achive.
      Thanks for reading, take on the chalenge πŸ˜‰
      Cookieschredder
      • A
        alex1811
        Hi Cookieschredder,
        It is rounded, not sure if this is exactly what you want to do but no need ruby to achieve this,
        • K
          Keksschredder
          Hi Alex, thanks for your quick response and nicely done tutorial. This is better than what i hoped for. But how do you keep everything selected while you click on the push/pull tool? When i select it, the sphere turns off.
          Cookieschredder
          • TIGT
            To say no Ruby is needed is misleading...
            You need to turn View > Hidden-Geometry 'on' [select all faces] and use the 'Multiple-PushPull' Plugin, then Group all and use the 'Subdivide and Smooth' Plugin to "round" the result...
            πŸ€“
            • K
              Keksschredder
              Thanks Tig, that helps a lot. now i got it. ...What can i say...
              thx guys
              Cookieschredder
