    Im no noob but this is a chalenge to me...
    5 Posts 3 Posters 876 Views 3 Watching
      Keksschredder
      Hi sketchers, since one picture explains as much as thousand words...here is my chalenge. (.png below)
      I found this picture and its the closest one to my conception. The only thing i want to change is, that the staves should be round. The guy who created this uses ruby. I hope there is a more simple way to achive.
      Thanks for reading, take on the chalenge πŸ˜‰
      Cookieschredder
        alex1811
        Hi Cookieschredder,
        It is rounded, not sure if this is exactly what you want to do but no need ruby to achieve this,
          Keksschredder
          Hi Alex, thanks for your quick response and nicely done tutorial. This is better than what i hoped for. But how do you keep everything selected while you click on the push/pull tool? When i select it, the sphere turns off.
          Cookieschredder
            To say no Ruby is needed is misleading...
            You need to turn View > Hidden-Geometry 'on' [select all faces] and use the 'Multiple-PushPull' Plugin, then Group all and use the 'Subdivide and Smooth' Plugin to "round" the result...
            πŸ€“
              Keksschredder
              Thanks Tig, that helps a lot. now i got it. ...What can i say...
              thx guys
              Cookieschredder
