    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 98.8k Views 35 Watching
      c.plassais
      @stefx said:
      I use Mac and it looks like it doesn't work..... ๐Ÿ˜ž
      any tips?
      stef.
      Oops!
      Sorry but I do not test on Mac.
      cmeed uses the plugin successfully on Mac
      can you send me a copy of the errors returned
      Christophe
        stefx
        Hi Christophe,
        I have solved the problem just restarting my Mac.
        Sorry for the trouble,
        Thank you for the amazing plugin!
        stef.
          c.plassais
          no problem
          it suits me ๐Ÿ˜‰
            c.plassais
            Hi Everyone,
            a new version ChrisP_ColorEdge 0.2.2
            Adding the management layer
            Draw an edge by layer, with a color of your choice or the color of the active layer.
            Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
            Dotted lines by filtering by layer
            Thank you to TIG for his plugin ListeLayerColors
            [flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
            Enjoy
            Christophe
              c.plassais
              Adding icons designed by Max (CadFather)
              Icons designed by max
              A big thank you max ๐Ÿ‘
              Christophe
                c.plassais
                ****14/07/2010 Version 0.2.3 Fixed problem layer's observer
                http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
                Regards
                Christophe
                • Y Offline
                  yvan79
                  good plugin to counter autoCAD colored edges....
                    jsteacy
                    Very cool, ๐Ÿ˜Ž
                    • P Offline
                      plf10
                      thank you for your share ๐Ÿ’š
                        dtrarch
                        Chris
                        A gotta have script and just super for tracing over scan'd drawings and such.
                        Thank you so very much. ๐Ÿ˜
                        Note that if one selects a color visually from materials it will be the default for the line tool color.
                        Works well especially as on can sample on screen colors too this way for repeats.
                        Cheers ๐Ÿ˜„
                        dtr
                          akigrimm
                          Is there anything special about the installation. I can't see the plugin in SU . I unpacked to plugins and it created a folder and a rb file ChrisP_ColorEdge_EN. Anything else? I would be very happy when I could draw dotted lines.
                            JuanV.Soler
                            It is under ...VIEW __TOOLBARS ^`...Color Edge
                              c.plassais
                              Thanks Juan ๐Ÿ‘
                                Builder Boy
                                Shade by 3 colors dosn't work for me ๐Ÿ˜ž Instead, it gives me the dialog, and when I click ok, NOTHING HAPPENS! ๐Ÿ˜
                                All my plugins
                                  JuanV.Soler
                                  Yes,
                                  I donยดt understand the tool neither. Use it for lines, enough for me. Sorry.
                                  I have to investigate though I have the feeling that it is not tunned yet or updated.
                                    c.plassais
                                    This tool allows to colorize the edges on a same plane by a mixture of two basic colors depending on the angle and possibly a second plane and a third color
                                      c.plassais
                                      [flash=800,600:3blf0ado]http://content.screencast.com/users/c.plassais/folders/Jing/media/b2d1840e-dcf4-4c4f-a71b-8de7ea7e272c/blend.swf[/flash:3blf0ado]
                                        schnydix
                                        hello i would like tranlate this plugin to german but how ?
                                        And it is Possible to have a different line width.
                                        Thanks for the great work
                                        best-off@gmx.net
                                          c.plassais
                                          Good evening,
                                          for the width lines it's not possible.
                                          I will soon publish a new version, including a Spanish version translated by Diego Rodriguez. The new version adds faces to the lines drawn.
                                          Can work on inner edges are groups and components.
                                          It is possible to include a German version. Here are the lines to translate
                                                 $aa_01 = "Length "
                                            	$aa_02 = "TAB to modify parameters "
                                            	$aa_03 = "Select the end of the edge == TAB to modify colors "
                                            	$aa_04 = "Color on axis X "
                                            	$aa_05 = "Color on axis Y "
                                            	$aa_06 = "Color on axis Z "
                                            	$aa_07 = "Color 45 degree "
                                            	$aa_08 = "Color other axix "
                                            	$aa_09 = "Color single "
                                            	$aa_10 = "Color "
                                            	$aa_11 = "Select the start of the edge == TAB to modify colors "
                                            	$aa_12 = "No color "
                                            	$aa_13 = "No RGB"
                                            	$aa_14 = "RGB "
                                            	$aa_15 = "TAB to modify colors "
                                            	$aa_16 = "By Layer "
                                            	$aa_17 = "No selection, do you want apply\nthe operation to all entities? "
                                            	$aa_18 = "Stippling "
                                            	$aa_19 = "% or cm "
                                            	$aa_20 = "Adapt length "
                                            	$aa_21 = "Color 1 "
                                            	$aa_22 = "Color 2 "
                                            	$aa_23 = "There are several instances\nDo make unique instance?\nOtherwise the definition will be modified... "
                                            	$aa_24 = "Angle length "
                                            	$aa_25 = "Angle color "
                                            	$aa_26 = "Edge color "
                                            	$aa_27 = "ColorEdge "
                                            	$aa_28 = "Draw Color Edge "
                                            	$aa_29 = "Draw edge by color by vector "
                                            	$aa_30 = "Edge single color on select "
                                            	$aa_31 = "Edge color by axis on select "
                                            	$aa_32 = "Modify select in dotted line "
                                          	$aa_33 = "Color Edge by click "
                                          	$aa_34 = "Dotted line by click "
                                          	$aa_35 = "Colored angle by click "
                                          	$aa_36 = "Colors blend "
                                          	$aa_37 = "Color select "
                                          	$aa_38 = "Colored angle "
                                          	$aa_39 = "Dotted line"
                                          	$aa_40 = "By default"
                                          	$aa_41 = "Active layer"
                                          	$aa_42 = "All"
                                          	$aa_43 = "Delete"
                                          	$aa_44 = "Color layer"
                                          	$aa_45 = "Keep"
                                          	$aa_46 = "Whithout"
                                          	$aa_47 = "Invisible"
                                          	$aa_48 = "Yes"
                                          	$aa_49 = "No"
                                          	$aa_50 = "Selection of colors to use"
                                          	$aa_51 = "Valid and save"
                                          	$aa_52 = "Valid"
                                          	$aa_53 = "Uncheck all"
                                          	$aa_54 = "Chech all"
                                          	$aa_55 = "Cancel"
                                          	$aa_56 = "Color choice "
                                          	$aa_57 = "Add face "
                                          	$aa_58 = "Inputbox setup "
                                          	$aa_59 = "Inputbox setup..........................................You must before colors selected "
                                          	$aa_60 = "Language choice "
                                          	$aa_61 = "List chosen colors "
                                          	$aa_62 = "Parameters "
                                          	$aa_63 = "Yes|No"
                                          ChrisP
                                            sketchupjockey
                                            thanks i will check it out.
                                            • 2 / 4
