    Changing text opacity levels?
    layout
    12 Posts 7 Posters 2.8k Views 7 Watching
    • keea1111K
      keea1111
      Is it possible to change the opacity level of text in LO, or turn text to grey?  Would be very helpful, but can't seem to get it to work.  Does anyone have any insight?  thanks,  Keea
      KEEA
      • B
        bjanzen
        PC or Mac? On Mac, command-t and the font panel has text color, and you can set opacity on the color inspector.
        • keea1111K
          keea1111
          thank you..that works great...Keea
          KEEA
          • GaieusG
            Those privileged Mac users...
            πŸ˜’
            • C
              chuck
              Don't know a way to alter text directly - but if you put a shape with Fill and Stroke set to background color and set both fill and stroke it to a percent of transparency, over the text it makes the text view and print as gray.
              Sample print out
              Life is to important to take seriously
              • C
                Charlie__V
                OK...how about on PC? (Win7)
                (I can set color......but pacity slider does nothing) 😞
                Thanks,
                Charlie
                • C
                  Charlie__V
                  Probably should have just asked if anyone else on PC can confirm no opacity control on LO text.
                  So...anyone?
                  Thanks,
                  Charlie
                  • C
                    Charlie__V
                    OK.....confirmed. πŸ˜’
                    C
                    • FrederikF
                      Frederik
                      You're right...
                      It's not possible to set the opacity of text color...
                      Would be a good idea to post a feature request... πŸ˜„
                      Cheers
                      Kim Frederik
                      • C
                        Charlie__V
                        You're right...
                        Frederik,
                        Thanks for confirming as well.
                        Not sure a feature request would help....apparently it is already a feature....only on Mac.
                        Hmm...can you run Mac OS on windows? (perpendiculars) πŸ˜›
                        Charlie
                        • M
                          marcdurant
                          When this thread started in 2010, the Mac client would allow setting the opacity of text, but the Windows client couldn't set or even display text opacity. To avoid confusion, we recently (LO 2013?) disabled the opacity slider on Mac so that the platforms match.
                          Thanks,
                          Marc
                          • C
                            Charlie__V
                            Thanks,
                            Marc
                            So........and please pardon........the (hopefully temporary)solution was to have no/0 "client" ability to set text opacity. 😳
                            C
