A vase
I was trying out a newly downloaded set of plugins (EEby...) and, combining it with roundcorners-plugin, made this vase... just wanted to show you guys
rendered in Artlantis, no post-pro
It looks pretty good, I mean the round corners.
Just thought it you could show some view with the caustics or vase's shadows.
And also about the enviroment, could you do one with an HDRIs? -
I could, but not in Artlantis. Will do tomorrow
I was playing around with some friends 3.0 and somehow didn't get use to some of the settings so I thought maybe you can shed some light.
Anyway I think you're doing great with renderings. Keep posting! -
That is a very nice vase Martha.
a close up please!! we cant see how much work you have put into the model at this range. all the details are lost. those tools are wonderful aren't they! I have no idea whatsoever how TIG makes these plugins!
Nice vase
Hi Pyroluna, That vase looks really nice!
could you post a wire?
Have you done the shape in just one step? -
Hi I'm back
Thanks for all the nice comments
So, mr D-Space.... you want to see a HDRI-lighted image with caustics??
Here it is:
Now as far as I know, Artlantis can't do either, so I rendered with Mental Ray for Maya. Helluvajob. 'scuse my frenchSo here's the wireframe...
In the middle, the final shape.
On the left, a section cut.
On the right: this is the shape I used to construct.- The four (or actually five, but I welded the bottom two) curves making up the nearest side of the cheesewedge were the starting point for an 'Extrude Edges by Rails' operation.
- The result rotated+copied, circle drawn on top, push-pulled. Bottom part mirrored to the top.
- Then copied, and scaled a bit in red&green, reversed faces. Then the outer shell extended downwards a bit further than the inner shell; the inner shell was push-pulled downwards just enough to use a maximum radius for 'round corners' to work without self-intersecting. The outer shell has a smaller radius at the bottom.
Hi I'm back
Here it is:Cool!
Thanks for the insight! -
Very nice!
Lovely work !!!
