    A vase
    12 Posts 8 Posters 1.3k Views 8 Watching
      D-space
      It looks pretty good, I mean the round corners. πŸ˜‰
      Just thought it you could show some view with the caustics or vase's shadows.
      And also about the enviroment, could you do one with an HDRIs? πŸ˜„
      http://blibestmentalt.no/54981
      • pyrolunaP Offline
        pyroluna
        I could, but not in Artlantis. Will do tomorrow πŸ˜„
          D-space
          I was playing around with some friends 3.0 and somehow didn't get use to some of the settings so I thought maybe you can shed some light. πŸ˜‰
          Anyway I think you're doing great with renderings. Keep posting! πŸ˜„
          • boofredlayB Offline
            boofredlay
            That is a very nice vase Martha.
            • olisheaO Offline
              olishea
              a close up please!! we cant see how much work you have put into the model at this range. all the details are lost. those tools are wonderful aren't they! I have no idea whatsoever how TIG makes these plugins!
              oli
              • CoreMaster110C Offline
                CoreMaster110
                Nice vase πŸ˜„ πŸ‘
                  KarinaGM
                  Hi Pyroluna, That vase looks really nice!
                  could you post a wire?
                  Have you done the shape in just one step?
                  **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                  -BenjamΓ­n Franklin.**
                  • pyrolunaP Offline
                    pyroluna
                    Hi I'm back πŸ˜„ Thanks for all the nice comments πŸ˜„
                    So, mr D-Space.... you want to see a HDRI-lighted image with caustics??
                    Here it is:
                    Now as far as I know, Artlantis can't do either, so I rendered with Mental Ray for Maya. Helluvajob. 'scuse my french
                    So here's the wireframe...
                    In the middle, the final shape.
                    On the left, a section cut.
                    On the right: this is the shape I used to construct.
                    • The four (or actually five, but I welded the bottom two) curves making up the nearest side of the cheesewedge were the starting point for an 'Extrude Edges by Rails' operation.
                    • The result rotated+copied, circle drawn on top, push-pulled. Bottom part mirrored to the top.
                    • Then copied, and scaled a bit in red&green, reversed faces. Then the outer shell extended downwards a bit further than the inner shell; the inner shell was push-pulled downwards just enough to use a maximum radius for 'round corners' to work without self-intersecting. The outer shell has a smaller radius at the bottom.
                      D-space
                      Here it is:
                      Cool! 😎
                      Thanks for the insight! πŸ˜‰
                      • Bryan KB Offline
                        Very nice!
                        • F Offline
                          FilipAGuy
                          Lovely work !!! πŸ˜‰
                          ASUS G73JH-A1 (ASUS G73JH-TZ002Z) i7-720 QM, RAM 8GB DDR3 1333 MHz, HDD 1TB (2x 500GB 7200 rpm), Blu-ray Combo, ATI Radeon HD 5870 1GB
