    A vase
    12 Posts 8 Posters 1.1k Views 8 Watching
    • pyrolunaP Offline
      pyroluna
      I was trying out a newly downloaded set of plugins (EEby...) and, combining it with roundcorners-plugin, made this vase... just wanted to show you guys
      rendered in Artlantis, no post-pro
        D-space
        It looks pretty good, I mean the round corners. πŸ˜‰
        Just thought it you could show some view with the caustics or vase's shadows.
        And also about the enviroment, could you do one with an HDRIs? πŸ˜„
        http://blibestmentalt.no/54981
        • pyrolunaP Offline
          pyroluna
          I could, but not in Artlantis. Will do tomorrow πŸ˜„
            D-space
            I was playing around with some friends 3.0 and somehow didn't get use to some of the settings so I thought maybe you can shed some light. πŸ˜‰
            Anyway I think you're doing great with renderings. Keep posting! πŸ˜„
            • boofredlayB Offline
              boofredlay
              That is a very nice vase Martha.
              • olisheaO Offline
                olishea
                a close up please!! we cant see how much work you have put into the model at this range. all the details are lost. those tools are wonderful aren't they! I have no idea whatsoever how TIG makes these plugins!
                oli
                • CoreMaster110C Offline
                  CoreMaster110
                  Nice vase πŸ˜„ πŸ‘
                    KarinaGM
                    Hi Pyroluna, That vase looks really nice!
                    could you post a wire?
                    Have you done the shape in just one step?
                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                    -BenjamΓ­n Franklin.**
                    • pyrolunaP Offline
                      pyroluna
                      Hi I'm back πŸ˜„ Thanks for all the nice comments πŸ˜„
                      So, mr D-Space.... you want to see a HDRI-lighted image with caustics??
                      Here it is:
                      Now as far as I know, Artlantis can't do either, so I rendered with Mental Ray for Maya. Helluvajob. 'scuse my french
                      So here's the wireframe...
                      In the middle, the final shape.
                      On the left, a section cut.
                      On the right: this is the shape I used to construct.
                      • The four (or actually five, but I welded the bottom two) curves making up the nearest side of the cheesewedge were the starting point for an 'Extrude Edges by Rails' operation.
                      • The result rotated+copied, circle drawn on top, push-pulled. Bottom part mirrored to the top.
                      • Then copied, and scaled a bit in red&green, reversed faces. Then the outer shell extended downwards a bit further than the inner shell; the inner shell was push-pulled downwards just enough to use a maximum radius for 'round corners' to work without self-intersecting. The outer shell has a smaller radius at the bottom.
                        D-space
                        Here it is:
                        Cool! 😎
                        Thanks for the insight! πŸ˜‰
                        • Bryan KB Offline
                          Very nice!
                          • F Offline
                            FilipAGuy
                            Lovely work !!! πŸ˜‰
                            ASUS G73JH-A1 (ASUS G73JH-TZ002Z) i7-720 QM, RAM 8GB DDR3 1333 MHz, HDD 1TB (2x 500GB 7200 rpm), Blu-ray Combo, ATI Radeon HD 5870 1GB
