    Scripts to use to construct an auger?
    10 Posts 4 Posters 977 Views 4 Watching
    • JClementsJ Offline
      JClements
      Is there a script that can be used in combination with one of helix scripts to make an auger?
      • Chris FullmerC Offline
        Got a picture of what you have in mind and what shapes in it are most troublesome?
        All my Plugins I've written
          JClements
          Hi Chris:
          I was thinking of drawing section of a fin, produce a helix, and a line defining the centerline of the shaft (or simply use an SU axis) and have the "tip" of the fin section revolve along the helix path.
          Perhaps a second script to draw the tappered threads of a screw.
            Something like this?
            • jeff hammondJ Offline
              jeff hammond
              a super roughed out quick try....
              curvemaker, extrude edges by rail, & joint push pull..
              dotdotdot
                Hi Jeff,
                Have you tried the screw.rb or k-tools?
                I asked a long time ago how to make a screw thread?
                and got some great suggestions.
                Just a thought?
                  Sorry John, you got the wrong guy - I was the only one who did not submit an attempt πŸ˜„ Was it Jeff's or rclub's that you were refering to.
                    Between Jeff, John , Chris & Rich it's Led to some crossed wires!
                    I meant to say 'Hi John'
                    oh well....
                    Hi John and Chris and Jeff, let's stop screwing around!
                      JClements
                      Yes, RClub. That is close.
                        JClements
                        Reclub: The screw script seemed to work (a bit quirky though). I did one revolution, made it into a component, and then made adjacent duplicates.
                        Jeff: I'm not sure how you used Extrude Edges by Rail. Could you diagram your method?
                        Thanks, John
