Scripts to use to construct an auger?
 Is there a script that can be used in combination with one of helix scripts to make an auger?
 Got a picture of what you have in mind and what shapes in it are most troublesome?
 Hi Chris: I was thinking of drawing section of a fin, produce a helix, and a line defining the centerline of the shaft (or simply use an SU axis) and have the "tip" of the fin section revolve along the helix path. Perhaps a second script to draw the tappered threads of a screw.
 Something like this?
 a super roughed out quick try....
 curvemaker, extrude edges by rail, & joint push pull..
 Hi Jeff, Have you tried the screw.rb or k-tools? I asked a long time ago how to make a screw thread?
 and got some great suggestions.Just a thought?
 Sorry John, you got the wrong guy - I was the only one who did not submit an attempt  Was it Jeff's or rclub's that you were refering to. Was it Jeff's or rclub's that you were refering to.
 Between Jeff, John , Chris & Rich it's Led to some crossed wires! I meant to say 'Hi John' oh well.... Hi John and Chris and Jeff, let's stop screwing around!
 Yes, RClub. That is close.
 Reclub: The screw script seemed to work (a bit quirky though). I did one revolution, made it into a component, and then made adjacent duplicates. Jeff: I'm not sure how you used Extrude Edges by Rail. Could you diagram your method? Thanks, John
