    SKU Pro 7.16860 works like crap!
    25 Posts 10 Posters 3.6k Views 10 Watching
      dficarra
      @gaieus said:
      Like Jim says, there is no difference between the Free and Pro (or eval) version of SU so if you experience anything like this, it MUST be something else.
      Is there a bunch of boxes that need to be checked or unchecked for optimum performance? If so, can someone provide me with a list of what to have checked and unchecked and I'll see if that makes a difference?
      Thanks.
        As Thom and Jim already suggested earlier, turning off Hardware Acceleration and Fast Feedback under Preferences should boost speed.
        But it doesn't seem like that's your problem? Could be a network issue with server?
          No - turning on boosts speed. You only turn off if you are having problems and want to check if it is a graphic card issue.
            I realise Hardware Acceleration boost SU performance but didn't get that across 😳
            What I meant was turning off would help isolate if the problem stemmed from the GPU. Then troubleshoot back from that point to which setting could be causing the fault.
            my suggestion with the networks comeS from problem I have in work where access to our server is in conflict with SU, Office, Outlook etc. Lenghty pauses for what was apparently no reason. Finally they solved by installing a filter of some sort which managed traffic to and from the server.
            Still not 100% but tolerable, though I solve by removing LAN cable completely which has added bonus of an email free day πŸ˜„
              Try working on a local copy of the SKP on your PC and see if than improves the 'speed'... if it does it's the network !
              • 2 / 2
