    Ruby script compatibility issue..IN vs. Metric
    5 Posts 5 Posters 1.2k Views 5 Watching
      conradcliff
      SketchUp version: 7.1.6860
      Operating system: XP SP3
      Hey guys, first post here, looks like a great forum πŸ˜„
      So I have a bit of a problem..I've created this fairly complicated drawing using components created for google sketchup by the company that provides the actual materials and machines them for you.
      Well, along with the components they provide a ruby script to create a bill of materials after you've finished your drawing...the problem is that you apparently You must being drawing with your Sketchup Preferences Template set to:
      "Inches (Woodworking) - 2D"
      I've drawn the whole thing up in the metric woodworking template since I was using their metric products.
      Below is the script they provide free of charge on their website, if anyone could give some insight on what needs to be done in order for it to work with the metric template, or if it could work at all, I would really, REALLY appreciate it. Thanks! πŸ˜„
      #v1.1.0
      def get_instance(ent, def_name)
         output = ""
         ent.instances.each do |e|
            orig = e.transformation.origin
           # output << "#{def_name},#{e.bounds.width},#{e.bounds.depth},#{e.bounds.height},#{orig.x},#{orig.y},#{orig.z}\n"
            output << "#{def_name},#{e.bounds.width},#{e.bounds.depth},#{e.bounds.height}\n"
         output
      def get_all_items
         out = ""
         Sketchup.active_model.definitions.each do |e|
            out << get_instance(e, e.name)
         out
      def get_instance_login(ent, def_name)
         output = ""
           # output << "#{def_name},#{e.bounds.width},#{e.bounds.depth},#{e.bounds.height},#{orig.x},#{orig.y},#{orig.z};"
            output << "#{def_name},#{e.bounds.width},#{e.bounds.depth},#{e.bounds.height};"
         output
      def get_all_items_login
         out = ""
            out << get_instance_login(e, e.name)
         out
      def export_items
         flomoco_login = "demo@flomoco.com"
         if(flomoco_login != "")
              model_data = "FloMoCo Component Reporter v1.1.0\n"
                 model_data = model_data + get_all_items_login
                 #model_data.gsub!('"','%22')
                 #model_data.gsub!('~','%7E')
                 web_data = "remail=" + flomoco_login + "&data=" + model_data;
                 dialog = UI;;WebDialog.new("FloMoCo 80/20 Instant Quoter", true, "FloMoCo_Quoter_Page", 50,50, 20, 20, true)
                 dialog.show
                 dialog.post_url("http://www.flomoco.com/c/8020_IQ_Login.pl",web_data)
                 UI.openURL "http://www.flomoco.com/c/8020_IQ_Login.pl?temail=#{flomoco_login}"
        else
              file_name = File.dirname(__FILE__)+"/FloMoCo_8020_BoM.txt"
                 f = File.new(file_name,"w")
                 f.write model_data
                 f.close
                UI.openURL "file;//#{file_name}"
      if( not file_loaded?("FloMoCo_8020_quoter.rb") )
          add_separator_to_menu("Plugins")
          UI.menu("Plugins").add_item("Generate FloMoCo 8020 BoM...") { export_items}
      end#if
      file_loaded("FloMoCo_8020_quoter.rb")
      • TIGT Online
        If they need the dimensions in inches set your model units to Inches in Model Info > Units.
        Open the Woodwork Inch template and note these settings and mimic then in tour model - you can swap units at any time. Sketchup uses Inches as its internal units, no matter what you model in. Indeed you can model in mm, you type 1000 OR 1000mm to get a line that length, BUT with your units still set to mm type 1m in the VCB and you'll get a 1m [1000mm] long line or even 40" to get one 40" long etc !
          I don't see anything in that code the relates to any units. Appear to be only a small part of the code. Something that has to be adjusted on their side. Have you approached them about metric support?
          • fredo6F Offline
            fredo6
            If the unit of your model is centimeter, then just add .cm at the end of the width, depth and height properties. This will convert them into inches to the output.
                 output << "#{def_name},#{e.bounds.width.cm},#{e.bounds.depth.cm},#{e.bounds.height.cm}\n"
            If your model unit is meter, then use .m instead.
            Fredo
              Jim
              After scanning the FloMoCo plugin, it don't see how it can be reporting the correct dimensions.
