    Translators
    57 Posts 6 Posters 3.9k Views 6 Watching
      I wasn't thinking that we change the existing terms in SU. Plugins should use the terms used by Sketchup for consistency. But it was more of a reflection on how computer terms are used. And when translating, when one feel that the word is lacking in the target language, then basing it on the original might not be the best. As in the case of an Edge - it's not always representing the edge of something. So when transfering that to a new language, one might want to think twice.
      Back to the case of French, and the term Edge - isn't there an French version of SU? What does it use?
        And what does the Entity Info window say when you select an Edge?
          Edge style = "Style d'Arêtes" in French version of SU 😉
          Display edges = "Affichages des arêtes"
          Profil = "Arêtes profilées"
          Depthcue = "Arêtes avec effet de profondeur"
          Extention = "Arêtes prolongées"
          French is some prolix 😆
          • Dan RathbunD Offline
            Dan Rathbun
            Entity info = "Infos sur l'entité" ("s" is always written even when only one thing is selected 😄
            ..., I see that English gives never s to "Info"
            because it's the noun that is pluralized:
            "Entity" (singular)
            "Entities" (plural)
            "Info" is a short slang for "Information"
            "Information" is not pluralized, just as "Data" is not.
            I'm not here much anymore.
              Entity info = "Infos sur l'entité" ("s" is always writed even only one thing is selected 😄
              French is prudent, I see that English gives never s to "Info" English is foolhardy 💚
              "Arête" again when one edge is selected 😉
              "2 Arêtes" when you select 2 edges 😄
                This explain that 😉
                  Dan Rathbun
                  I think TT wants to know what the object title says in French.
                  (The dialog title is always the same.)
                  If a single edge is selected, it says "Edge" (in English.)
                  But when many objects are selected, the object title says (in English.): "n Entities" where n is the number selected.
                  Pilou already said ...
                  "Arête" [] when one edge is selected
                  "2 Arêtes" when you select 2 edges [etc]
                  Sp a Sketchup Edge is an 'Arête' in French, although a direct translation might give us 'Bord'... but it's not used in SUp...
                    Dan Rathbun
                    This is an example of non-direct translation.
                    Info de l'entité = Entity Info
                    Infos sur l'entité = About the entity
                    (If you capitalize the 'e' in entité, the Google translator gives "Entity Info" in English, for both phrases.)
                    Propriétés de l'Entité = Entity Properties
                      Yes it's the fix's title on the French SU Window info box !
                      In SU English Title is also fixed!
                      Ps Entities is very elaborate, elements is more curent 😄
                        Dan Rathbun
                        Yes it's the fixed title on the French SU Window info box !
                        elaborate = formal?
                        We cannot call them element because the Ruby classname is Entity, and the Ruby collection of them is named Entities.
                        So we must be formal.
                          elaborate = literary 😄
                            Here's an example of a Norwegian translation problem:
                            Face = Overflate
                            Overflate is directly translated as Surface - as direct translation of Face doesn't sound good.
                            But, in SU there is a distinction between Face and Surface. If you click on a Face where the adjacent faces are separated by a soft edge, Entity Info then displays Surface.
                            That leads to a problem when translating to Norwegian, as one need to find a way to distinguish between Face and Surface., despite that both words really would have been translated as Overflate.
                            Using the MS search tool is of no futher help, as it only lists Overflate as translation for Face.
                              In English you can Inflate, Deflate, Reflate, Under-inflate and Over-inflate but not Overflate [though 'overflated' is sometimes used incorrectly to mean 'overinflated'] !
                              These are all generally to do with increasing or reducing something - like 'economic inflation, or to inflate a car-tyre' 😒
                                Dan Rathbun
                                Face = Overflate
                                In English the dimunitive of Face is Facet (considering 'Face' to be normative,) and the superlative is Surface. Athough SU doesn't seem to use all 3 heirarchal terms, you might use the dimunitive Fasett in Norwegian for Face, and the superlative Overflate for Surface, (if you don't think Flate sounds good for Face.)
                                  hm... interesting.
                                  Though Fasett is not something that I'd immediately accommodate with a geometric Face.
                                  Flate is a nice short word. At first I wasn't really sure - thinking it had too much of the meaning of Overflate. But giving it a second thought - I like it.
                                  Edge = Linje
                                  Face = Flate
                                  Surface = Overflate
                                  Would be interesting to see if I can find some 3D software in Norwegian that uses similar terms.
                                  Well Dan - you make a better judge of Norwegian than I. 😄
                                    a quasi miracle 💚
                                    English : French
                                    face : face
                                    facet : facette
                                    surface : surface
                                      Dan Rathbun
                                      Naw... I'm just playing with the Google Translator:
                                      http://translate.google.com/?hl=en&tab=wT#en|no|
                                        Says something about my own grasp of my own language... 😳
                                          Dan Rathbun
                                          a quasi miracle 💚
                                          English : French
                                          face : face
                                          facet : facette
                                          surface : surface
                                          Not really a miracle, Pilou.
                                          All 3 words came into English, from the French (probably after the Norman conquest,) and originally came into French from Latin.
                                            Advantage of the invasions 😉
                                            • 2 / 3
