    [Plugin] Lattice Maker
    149 Posts 69 Posters 350.2k Views 68 Watching
      Copyright 2010-2013 (c), TIG
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      latticeMaker.rb
      Description:
      Takes a Selection of Faces and makes a Lattice, offset by a frame's given
      width and depth, and pane inset, you can also assign limited Materials
      to the frame/pane for ease of future selection/manipulation.
      It is similar to EEbyRailsToLattice BUT works on selected Faces...
      Usage:
      Make a 3D Mesh - perhaps using EEbyRails or other tools - remember that
      Faces need not be triangulated if all Edges' Vertices are 'coplanar', so
      using similar profiles/rails will allow 'quad faces'. You can also
      manually draw over faces to sub-divide them as required.
      Edit the Group and Select the Faces to be converted into a Lattice -
      any Edges etc in the Selection are ignored so you don't need to be too
      careful. Note that the Selected Faces and their Edges that are not
      required by non-selected Faces will be deleted and replaced by the new
      Lattice Group - if you want to keep them make a copy of the original mesh
      to one side beforehand...
      Note that a Lattice frame is made in the direction away from a Face's
      'front', so if you want the frames and pane to be formed in the other
      direction 'Reverse' the Selected Faces beforehand.
      Run 'Lattice Maker', from the Plugins Menu.
      You are then prompted to chose the 'Lattice Properties':
      'Width' - default is 50mm/2" - this is the width centered on the
      lines so it's effectively a 100mm/4" 'frame' overall where faces abut.
      [if <=0 it defaults]
      'Depth' - default is 50mm/2", this is measured 'in' from the face
      [if==0 there is no 'depth', if <0 it defaults].
      'Pane Inset' - the amount the pane is inset from the frame's top-face -
      default is 25.mm/1" [if ==0 there is no 'inset', if <0 it defaults;
      it can never be more than the depth, and reverts to that if it is].
      'Pane Thickness' - the thickness of the pane measured inset from the
      pane's top face - default is 5mm/0.25" [if ==0 the pane is 'one sided'
      (facing 'out'), if <0 it is 'outset', this -ve 'outset' cannot be > the
      pane_inset, the pane_thickness is limited to the frame_depth-pane_inset].
      It is best to give the pane a thickness if it is to be seen from both
      sides and the lattice might be exported to a 3rd party renderer.
      'Lattice Material' - default is <Default> - additional choices are 'Red',
      'Orange', 'Yellow', 'Green', 'Blue', 'Violet', 'Black', 'White' or 'Gray'.
      'Pane Material' - default is <None>** - additional choices are <Default>,
      "Glass"***, 'Red', 'Orange', 'Yellow', 'Green', 'Blue', 'Violet',
      'Black', 'White', 'Gray'.
      **Note: if Pane Material == <None> then the faces that would form them
      become 'holes' in the final lattice.
      ***The 'Glass' material will be made if it doesn't exist - it is colored
      'bluish-light-gray' with 30% opacity.
      The Faces' edges are now offset to suit, then pushpulled to suit and the
      materials applied.
      Note that faces that are too small to have a 'pane' are made 'solid'.
      Download it from the 'SketchUcation PluginStore' http://sketchucation.com/resources/pluginstore?pln=latticeMaker
      OR AutoInstall using the 'SketchUcation Plugin Store' dialog from within SketchUp itself
        Slimdog
        That looks like fun.
        I will have to get around to it someday.
        Thanks for sharing.
        Steve
        • mitcorbM Offline
          mitcorb
          Looks interesting. One to watch.
            rickgraham
            You never cease to amaze me with your plugins. Thank-you! 😍
            Rick
              Can be very usefull for Stained glass! 😎
              You have the rythm! 😲 👍
              A "simple" Windowizer ?
              • E Offline
                eddy
                cool plugin TIG
                thanks, thanks,thanks. 👍 👍 👍
                @ ++ Eddy
                  Very nice. 👍
                  • honoluludesktopH Offline
                    honoluludesktop
                    WOW, Fantastic.
                      jchau2007
                      TIG,
                      Another great plugin. As always, thank you. 👍
                      • X Offline
                        xrok1
                        👍 good one!
                        of course you realize we're going to have to see a bunch of furry lattices now! 🤢
                        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                          remus
                          ...or latticed fur 😄
                          • X Offline
                            xrok1
                            or furred, latticed fur! 😲
                              Maybe some fertilizer necessary! 😆
                              • P Offline
                                Panga
                                Love that furred, latticed fur! 🤣
                                  dylan
                                  Thanks Tig.
                                  http://dmdarchitecture.co.uk/
                                      rv1974
                                      must have tool for architects. Thank you Tig!
                                        Jim
                                        Thatched roofs are possible now?
                                        • olisheaO Offline
                                          olishea
                                          TIG: will it catch on? of course it will!
                                          have you seen this building? your plugins+fur will surely facilitate this process.
                                          http://www.284brasil.com.br/blog/wp-content/uploads/2010/04/shanghai_expo_pavilion_heatherwick_studio_expo2010-yatzer_3.jpg
                                          oli
                                            saturne45
                                            Great works mister TIG...
                                            • 6
                                            • 7
                                            • 8
                                            • 1 / 8
