    [Plugin] PickIt
    13 Posts 8 Posters 23.9k Views 8 Watching
    • thomthomT
      UI
      Tools -> PickIt
      Supports ThomThom's Menu
      Usage
      • Click to select best picked entity.
      • Right-Click for a list of alternative entities.
      The main usage here is the Right-Click menu when you have several overlapping entities that are hard to select. Right-click and select from a list of all entities under the cursor in the current context.
      Note that there are no way to add or subtract from the current selection. It is a quick and dirty script. I might update this in the future.
      http://sketchucation.com/pluginstore?pln=tt_pickit
      • CadFatherC
        CadFather
        Thanks Thom
        • E
          eddy
          cool plugin
          thanks, thanks,thanks Thom. πŸ‘ πŸ‘ πŸ‘
          @ ++ Eddy
          • S
            stefx
            It seems that the plugin doesn't work with Mac.
            Am I wrong?
            Stef.
            • thomthomT
              Worked fine on my old MacMini G4 OSX 10.4.
              Where did you install it?
              • S
                stefx
                Sorry for the trouble...
                I have solved the problem!
                Thank you very much!
                it is really helpful!
                Stef.
                • thomthomT
                  What was it?
                  (In case someone else asks this)
                    The Thomthom menu works with SU V6?
                    • thomthomT
                      Should do. I'd think it'll work with SU4 if you really insist. πŸ˜‰
                      • S
                        stefx
                        Thank you Thomthom!
                        The problem was that....I was looking for Pickit in the plugin bar instead it is in the Tool one.
                        sorry.....
                        πŸ˜‰
                        Stefx.
                        • Mike LuceyM
                          Mike Lucey
                          This will be useful πŸ‘
                          • JClementsJ
                            JClements
                            Glad someone decided to do this, Thomas.! Thanks.
                            I talked with SU folks at the first base camp about how Rhino was able to this with overlapping geometry and how useful it was.
                            • E
                              Einstein
                              Hello,
                              After years of using this plugin flawlessly, today I have a problem with it. It works perfectly fine with SU 2021, but in SU 2020 it just disappeared from my Tools menu. I was doing some plugin cleanup and I disabled and threw away some of them, but PickIt is installed and enabled, and I don't think it has any dependencies that I could have carelessly removed. I tried reinstalling it, but it didn't help. I also cannot find PickIt on the Shortcuts (Preferences) list.
                              What could have gone wrong?
                              I tried selecting and deselecting stuff inside and outside groups, but it doesn't change anything either.
