    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      There is no Max! Or in any case more than 20! πŸ˜‰
      Seems numbers of object = Density * 10 so be careful!
        Jorgensen
        hi pilou
        it seems to make no difference if i select a density of 5 or 20, the polygons never get more than 10017.
        i'm properbly do something wrong, but i don't know what πŸ˜•
        sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
          Jorgensen
          My fault - i set density to high.
            amos_miers
            Has anyone experienced the generation of the items heavily in some portions and light in others, following hard diagonal lines dividing the place? I cannot seem to apply the script evenly in most of my spaces. I am using 2014.
              If they are visible : Cleanup by Thomthom : Merge Coplanar Faces
              If they are invible, Enable Hidden Geometry : Selection Toys by Thomthom
              Select Soft or Smooth Edges then kill them
              • hajkardiH Offline
                hajkardi
                I have problem on slope terrain with plugin. I try to change all parameters but no luck?! Some parts of terrain is cover properly, but some have lack of grass. I download last version of plugin 2.1.0 and I have Sketch 2013 pro.
                http://i.imgur.com/k02tm7X.jpg
                  Ayomidotun
                  Thanks Bro!
                    tak2hata
                    Hi,haikardi.
                    Sorry for my reply too late.
                    I guess the problem is "MaxNumber(/Face)".
                    Please set high value to "MaxNumber(/Face)".
                    "MaxNumber(/Face)" is limit for creating too much fur.
                    Thanks!
                    by TAK2HATA
                    • soloS Offline
                      solo
                      I love this plugin, really helps me to distribute grass proxy's. I do have one request, sometimes even the lowest values are too much, I'd really like to distribute (make crowd) with .5, .2 values.
                      Oh!v a distribution brush would also be most welcome.
                      http://www.solos-art.com
                      • jiminy-billy-bobJ Offline
                        jiminy-billy-bob
                        What do you mean by that?
                        Something like Components Spray?
                        • V Offline
                          Vincy_PC
                          how to install in skp 2014?
                            Read the first post of this thread.
                            • V Offline
                              Vincy_PC
                              how install in skp 2014
                              • BoxB Offline
                                [screenr:27dfvywo]o3nN[/screenr:27dfvywo]
                                  jiminy-billy-bob
                                  how play the video
                                  • cottyC Offline
                                    cotty
                                    play good
                                    my SketchUp gallery
                                    • soloS Offline
                                      solo
                                      Please, I ask again if it would be possible to go lower than 0.1 in crowd place setting, I love this plugin but on a large terrain I seem to have no control as lowest setting is still too much.
                                      • F Offline
                                        feyade
                                        @lasrador said:
                                        This is just brilliant.. Don't know how i missed this for so long. Now that vray2.0 is proxy enables the possibilities are limitless.. Convert a grass component into a proxy on sk (Though 3dsmax allows the porxy to be simplified further), import it into the model and scatter the proxy. You have a feather weight model with the punch of a heavy weight! Awesome work tak2hata! 😍
                                        this was my first attempt at grass..
                                        http://i42.tinypic.com/ncdyf6.jpg
                                        hi,
                                        quick question how did u manage to achieve this render. can't figure how to setup my settings
                                        • H Offline
                                          hilalevi
                                          it doesnt work on sketchup 2014. what do i need to do to make it work?
                                            Yes. It does work on SketchUp 2014. The first thing you need to do to get help making it work is give specific and useful information. How did you install it? Which version? What are you expecting to see that you aren't seeing?
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 30 / 33
