    Convert walls to planer surfaces
    5 Posts 4 Posters 722 Views 4 Watching
      ddraynor
      So I am using IES VE (http://www.iesve.com/content/default.asp?page=) to perform energy analysis on a building. The problem is architects don't use SketchUp the way that the plugin for IES works. They model the walls as 3d walls instead of as planer surfaces. What would be the easiest (fastest) way to convert these models to flat planer surfaces. The tools I have available outside of SketchUp include Revit MEP 2010 and AutoCAD MEP 2010. I mention AutoCAD because a 2d floor plan as a DXF (still only wall centerlines) will also work for me.
      Any suggestions would be greatly appreciated.
      Thanks,
      David Raynor
        http://forums.sketchucation.com/viewtopic.php?p=242472#p242472
        has just started to discuss turning 3D walls into planes - spooky or what ? πŸ˜‰
          mac1
          Thanks,
          David Raynor
          David
          Looking at the IES site they have some PR about a IES sketchup plugin in a Sketchup intergration study they were doing. If you have a complex building converting the 3d walls to a plane can be man power intensive so a quick call to them may be helpful. Also find thomthom's plugin selection toys at the SCF plugin forum http://forums.sketchucation.com/viewtopic.php?f=323&t=14975&hilit=+Selection+Toys+ ( look down about 2/3 in this link for the download)which allows you to select edge loops with one click, hiding a wall selection, selecting wire frame face style, doing a right to left select to select and delete the non select part and then unhide could be quicker for you. In the wire frame style hidden geo is not selected.
            dylan
            There is going to be some work involved whichever method you use.
            This work will be far easier if the building is modelled correctly using groups, components and layers.
            Thinking off the top of my head, what I would do if I received a 3d model with wall thickness is, go to plan view and turn off the roof to reveal all internal walls. I would push pull them back down to floor level, which will leave the outline on the floor. You would need to make sure there is a line drawn where the internal wall meets the outer wall so you do not push everything down. You could then just draw a few lines using the pencil tool and the inference engine to quickly add back the faces of the walls. I guess what may need some thought is how accurate you need these wall positions? If you need to create a wall with thickness as a single plane, you may need to create this plane central to the said wall.
            http://dmdarchitecture.co.uk/
              mac1
              DAVID
              Spent some time on the IES site and even thought they have discussed their plan for a SU thick wall capability I am thinking that cahange is not near term for you. They make a recommendation external walls are modeled ref to out side wall location and for internal use the center line ref per your post.
              Suggest you post your SU model or a portion thereof if you have some proprietary issues because how changes are made will be influenced by how the model is made. I get the idea IES wants either components or groups for their model. Assuming you have the rooms presently modeled that way changing out one model for another may not be that difficult using the SU select and replace component functionally.
              Good Luck
