    [Plugin] Extrude Edges by Rails to Lattice
    73 Posts 25 Posters 95.9k Views 25 Watching
      That rules now πŸ‘ 😎
            πŸ˜‰
            http://forums.sketchucation.com/download/file.php?id=47505
              saturne45
              • olisheaO Offline
                olishea
                this is seriously amazing! been playing with it for hours now! just a question TIG: is there a way to group separately the "glass panes" from the frame? so the frame is one group and the panes are another...... πŸ˜•
                oli
                • N Offline
                  notareal
                  Wow, you did it again!
                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                    Give the frames and panes different colors - say 'red' and 'glass'.
                    Edit the group and select a pane.
                    Right-click Context-menu > Select > All with same Material...
                    All the panes are selected, Right-click Context-menu > Group.
                    Repeat for the frames.
                    You now have the original lattice group that contains two sub-groups - one for the panes the other for the frames.
                    Re-color them as desired.
                    One of the reasons I gave a limited 'rainbow' of colors+glass was to avoid long material lists in the dialog which always causes grief when the color you want is off the screen... and as explained above you can always select everything by a material and apply any color/material onto them that you like later on... πŸ€“
                    • simon le bonS Offline
                      simon le bon
                      playing:
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_011_th.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_012_th.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_013_th.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_014_th.jpg
                      I don't see how I could do the same with else tools ❓
                      *s
                        Maybe 2 faces + path + FFD(or fredoscale) πŸ˜‰
                          simon le bon
                          Thank you so much Dear Tig for this new amazing tool. πŸ‘ πŸ‘
                          @tig said:
                          Tip
                          You are prompted to erase coplanar edges if the faces can survive without triangulation divisions.
                          To ensure that you get 'flat' quad faces make sure that the profiles and rails are identical [perhaps copy them].
                          Pretty good tip!
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_001_th.jpg
                          I wanted to tell this one, but I'm outstripped by TIG πŸ˜„
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_002_th.jpg
                          another interesting result is to adjust the depth to 0 in order to get a flat frame
                          (and use soften & smooth for a simple aspect)
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_003_th.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_004_th.jpg
                          The tool 'EEbyRailsToLattice' was written to do a 3D lattice or the profiles/rails rib-lines as simple separated curves - so you can use them for other things - like 'EEbyFace' using different profiles for different parts...
                          πŸ€“
                          Extrude Edges by Rails to Lattice + ExtrudeEdgesBy2Faces
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_005_th.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_006_th.jpg
                          Extrude Edges by Rails to Lattice + ExtrudeEdgesByEdges
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_007_th.jpg
                          Extrude Edges by Rails to Lattice + ExtrudeEdgesByEdges + ExtrudeEdgesByRailsByFace
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_008_th.jpg
                          Extrude Edges by Rails to Lattice + Chris Fullmer tools
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_009_th.jpg
                          Extrude Edges by Rails to Lattice + Didier Bur "lines to tubes" (with and without EEbRtL)
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_010_th.jpg
                          etc.. etc..
                          Vast possibilities πŸ‘ πŸ‘
                          %(#0000BF)[Dear TIG, may I comment ? πŸ˜•
                          -Extrude Edges by Rails to Lattice uses only ExtrudeEdgesByEdges. I would be really cool if we would be able to pick curves the same starting from ExtrudeEdgesByLoft and also from ExtrudeEdgesBy2Faces or from ExtrudeEdgesByLathe !
                          -Do you think it would be possible to select also the diagonal curves family?]
                          with my friendly respect, simon.
                            Here's an update http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
                            It now has 'Diagonals' as an option.
                            Reversing the order of picking the Rails swaps the direction of the diagonals.
                            The lingvo files have been updated to match.
                            • olisheaO Offline
                              olishea
                              cheers for grouping explanation.I think i clicked select all connected by color or something.....oopsy 😳
                              fantastic work TIG, hats off!
                              oli
                                As you refine more and more does it possible to generate a "2 colors Checkboard" from the lattice?
                                β˜€
                                I have missed one case πŸ’š
                                  As you refine more and more does it possible to generate a "2 colors Checkboard" from the lattice? β˜€ [attachment=0:2q921w1c]<!-- ia0 -->checker.jpg<!-- ia0 -->[/attachment:2q921w1c]
                                  Pilou !
                                  Maintenant vous 'prenez la pisse' !
                                  However, it would be relatively easy - the panes are stored as an array in the logical order they are made.
                                  We know the number of them down the rail and across the profile.
                                  If the number of profiles is odd then every other one is colored, if it's even then every other one is colored, BUT swapping the rule over at every 'rail' step change...
                                  If you separate out the panes by selecting by material and grouping they will remain ordered.
                                  Then find the group's faces...
                                  group=Sketchup.active_model.selection[0]
                                  panes=[]
                                  group.entities.each{|e|panes<< e if e.class==Sketchup;;Face}
                                  0.upto(panes.length-1) do |i|panes[i].material="black" if i/2==1/2.0; end
                                  Swap "black" for your desired color...
                                  This works for odd-numbers of panes across the profile - I'll leave you to do the line of code to do it for even-numbers... πŸ˜‰
                                    I will examine that πŸ˜„
                                    I hope that can be input in the ruby console 😳
                                    For the French line does it possible to have the original
                                    because seems the translator gives a very exotic result πŸ˜†
                                    something like that! 🀣
                                    http://www.fotosearch.fr/bthumb/LIF/LIF139/NU106007.jpg
                                    • olisheaO Offline
                                      olishea
                                      lost in translation
                                      oli
                                        It's actually the same is English !
                                        Even the same word, but without the 'e'.
                                        Means much the same thing, 'faire pipi'...
                                        We say "taking the " = making an unwelcome joke.
                                        A convoluted way of saying someone is making a bad joke at your expense is to say, "You are extracting the urine, aren't you?".
                                        C'est comme 'chier' ?
                                        Noteworthy: to be "ed" is to be drunk [intoxicated] in the UK, but it means very fed-up or in a bad mood in the USA.
                                        In the UK we would used "ed off" to be very fed-up or in a bad mood...
                                        Which confusing is a vulgar way of saying that someone has left unexpectedly [probably in a bad mood] - e.g. "He's ed off !" = He has [just] left here.
                                        Then to be on the '
                                        ' is to be out on the town drinking.
                                        To be a drunk is a to be a '
                                        -head' [pejorative].
                                        To waste something valuable is to '
                                        it up the wall'.
                                        Whilst something of unacceptably low quality is said to be '
                                        -poor' !
                                        In construction '****ed' means to be out of plumb - not vertical: e.g. "That door-frame is ****ed".
                                        All very confusing πŸ˜•
                                          Ok I see what do you mean πŸ˜„
                                          But that is absolutly not the same in French πŸ˜‰
                                          That don't exist with this liquid for these meanings! πŸ’š
                                          A very familiar slang can be "vous vous foutez de moi" = you exagerate, you overpass the limits, you take me for a fool...
                                          (or "tu te fous de moi" between best friends )
                                          More elegant : "Vous vous moquez du monde", "Vous ne manquez pas d'air", "vous me prenez pour un pigeon, une andouille" etc... πŸ˜†
                                          "Vous me faites chier" is the ultimate, insurmontable, for something who is absolutly obstrusive disturbing in the univers of the person! πŸ˜‰
                                          But very slanguy language indeed! πŸ˜’
                                            So, we both learn how to cuss better in our respective languages !
                                            πŸ˜‰
                                            So, don't mess with me dude ! πŸ‘Š
                                            • 2 / 4
