    Urgent help pls
    10 Posts 4 Posters 1.7k Views 4 Watching
      mspisz
      Hello,
      I wonna make a shhpe that has two faces, one on top and one on the bottom... they are both different as you cna see in the screenshot...
      What I want to do is have a pattern (as youc an see secodn screenshot) taht goes in bewteen them all around teh edge... I used the Chris Fullmers plugin "component stringer to get teh pattern to go all around nicely but I want the patter to be thinner in some places... I have no idea how to do it... Iw as thinking maybe if I had the pattern follow two lines (edges of each of the top and bottom faces) then it could of been done quicker and more efficent.
      Thank you,
      Milo
      Here you can see the top is perfectly aligned
      Here you can see the space in bewteen where the pattern should go around
      As you can see here the pattern is not alligned with the bootom face
        Here's a similar example made with some curves, albeit in several sub-steps, using ExtrudeEdgesByRails.rb... ❓Capture.PNG
          mspisz
          Ok... I tried searching for it but didnt find it.... can u give me a dl link please...
          Thank you,
          Milo
            http://forums.sketchucation.com/viewtopic.php?p=201286#p201286 takes you to the page explaining how to use it.
            At the end of that page is a link that takes you to a page with a link to download all of the EEby... tools, in a single zipped set - download and install them following the instructions...
              mspisz
              Thanks for that,
              One more thing....
              I am using weld tool but for some reason it wont weld all those lines into one... it sometimes welds like half of it...would u know why? There are two ends....
                mspisz
                Got it done... thanks man helped me alot πŸ˜‰ saved my ass to be honest
                  mspisz
                  One more thing...
                  Is there a way to use two rails to get a group or component duplicated all along it ?something like component stringer but also like the extrude edges by rails....
                  Thanks,
                  Milo
                  • soloS Offline
                    solo
                    Milosz, is that a shoe you are modeling?
                    http://www.solos-art.com
                      mspisz
                      Nope.... school project
                      • brookefoxB Offline
                        brookefox
                        "I went to shoe school..."
                        ~ Brooke
