Urgent help pls
10 Posts 4 Posters 1.3k Views 4 Watching
    mspisz
    Hello,
    I wonna make a shhpe that has two faces, one on top and one on the bottom... they are both different as you cna see in the screenshot...
    What I want to do is have a pattern (as youc an see secodn screenshot) taht goes in bewteen them all around teh edge... I used the Chris Fullmers plugin "component stringer to get teh pattern to go all around nicely but I want the patter to be thinner in some places... I have no idea how to do it... Iw as thinking maybe if I had the pattern follow two lines (edges of each of the top and bottom faces) then it could of been done quicker and more efficent.
    Thank you,
    Milo
    Here you can see the top is perfectly aligned
    Here you can see the space in bewteen where the pattern should go around
    As you can see here the pattern is not alligned with the bootom face
      Here's a similar example made with some curves, albeit in several sub-steps, using ExtrudeEdgesByRails.rb... ❓Capture.PNG
        mspisz
        Ok... I tried searching for it but didnt find it.... can u give me a dl link please...
        Thank you,
        Milo
          http://forums.sketchucation.com/viewtopic.php?p=201286#p201286 takes you to the page explaining how to use it.
          At the end of that page is a link that takes you to a page with a link to download all of the EEby... tools, in a single zipped set - download and install them following the instructions...
            mspisz
            Thanks for that,
            One more thing....
            I am using weld tool but for some reason it wont weld all those lines into one... it sometimes welds like half of it...would u know why? There are two ends....
              mspisz
              Got it done... thanks man helped me alot 😉 saved my ass to be honest
                mspisz
                One more thing...
                Is there a way to use two rails to get a group or component duplicated all along it ?something like component stringer but also like the extrude edges by rails....
                Thanks,
                Milo
                  Milosz, is that a shoe you are modeling?
                    mspisz
                    Nope.... school project
                      brookefox
                      "I went to shoe school..."
                      ~ Brooke
