    Sketchup and frustration
    6 Posts 4 Posters 700 Views 4 Watching
    • kenK
      ken
      Well, recently I had the contents menu drop out the Unlock function. It didn’t even show up in the Edit section of the menus, I mean it wasn’t in the edit menu even grayed out. unlocked was not an option in the contents or edit menu when I picked a lock group.
      So I had a group locked, and couldn’t unlock. Fortunately it came back after I shut down the computer and restarted.
      But, damn couldn’t someone at Google figure out why the contents menu drops out. Right now I have the plugin, Drop and Drop at Intersection still grayed out. I go though shutting down and restarting maybe 5 to 10 times a day. It would be more, but I don’t shut down unless I really need to access a particular plugin.
      And could there be some way, that someone at Sketchup, certify that a plugin is written in such way that it "should not", (not looking for a guarantee) interfere with Sketchup. So there could be a list of certified plugins and a plugin writer could lists his/her plugin as being certified as not destructive.
      Oh, never mind, that would require actually caring about your product.
      Frustrated and damn annoyed.
      And onto another subject. I have TubroCAD 17, DoubleCAD2,and ViaCAD 6, all three will open a Sketchup file. But, darn if the drawing is usable after opening.
      I export all my Sketchup files as 2D CAD files, for making a set off fabrication drawings. Does anyone, have a work flow where they open up a Sketchup file into another CAD program, not a rendering program, and actually get some use from the process?
      To me, it seems to be just a waste of time trying to use raw Sketchup files in another CAD program.
      Lighter note.
      Darn if I wasn't making a living off of Sketchup, I wouldn't even bother with this program again.
      Ken, peeved in SC
      PS, Thanks to all you plugin writer, if it wasn't for you, I would actually have to show up in the office more than once every 6 months.
      Not so peeved now, writing this helped me to settle down.
      Again thanks to this forum and the help it provides.
      Ken
      • R
        remus
        I can quite confidently say that would be a very wasteful exercise. Plugin authors themselves have a hard enough time getting their plugins working properly and they know the code like the back of their hand. For somebody unfamiliar with the code to try dissect even a moderately complex plugin would take an age.
        A minor point though, i agree with the main jist that the greying out bug is extremely annoying.
        • TIGT
          I fail to see how simple ruby plugin could remove lock/unlock from your context or edit menus... It's hard enough to do anything to a menu with the API as it is !
          The 'Entity Info' window also gives access to the 'Locked' function via a tick-box... is this still there ?
          Sounds like a flaky SUp installation !
          This 'graying-out' bug is getting ridiculous and Google must address it asap... 😞
          • EdsonE
            Edson
            sketchup and vectorworks work very well together. skp files are imported into VW smoothly.
            http://www.mahfuz.arq.br
            • kenK
              ken
              The Unlock function was not available in the context or edit menu. Not even grayed out. It did not come back until I shut down the computer and restarted.
              Ken
              • TIGT
                Ken
                OK, I understand that, BUT when it's 'gone' from those locations is 'Locked' tickbox still available in the Entity Info Window [in its expanded format] ?
                Or has the function simply vanished ? This suggests a corrupted SUp installation not a Script problem to me...
