    Questioning about possibility of complex sections
    4 Posts 3 Posters 484 Views 3 Watching
    • J
      jackalvn
      Hi all!
      I have a shape as shown in the attachment file below
      I want to make a section through it as you see in the picture.
      How is it possible in Sketchup?
      Thks for your attention!
      about_sections.skp
      • thomthomT
        You can have one active sectioncut per contex. So you can group it, place a section cut inside the group, exit the group and add a secction cut in model space.
        You can add more sections cut, but they all needs to be in separate groups. And it'll only work for convex sectioncut paths.
        • massimoM
          massimo Moderator
          Hi, the easier way in simple models like yours is to draw two planes on your reference section lines then select them and right click-->intersect with model. Then you can erase the unwanted geometry. πŸ˜„
          • J
            jackalvn
            thank you!
            I will try. Hope it works
