    VRay & UVmap?
    renderpluginsextensions
    11 Posts 3 Posters 1.7k Views 3 Watching
    • V Offline
      vintorix
      I am completely new to VRay, I have only one question.
      1. If I make a fast model using Sketchup material VRay render it without problem.
      2. Likewise there is no problem with VRay material.
      3. But, if I import a model with UV & textmap (Via 3ds or COLLADA) Vray ignore the material and shows only a white surface. What am I doing wrong?
        Can you post screenshot and/or sample model?
        (Also - please mention what version of VfSU you use when posting.)
        • V Offline
          vintorix
          Here is a screen shot of the model. It has 2 UV/texture maps each 4096x4096 px.
          As you see Sketchup shows the model correctly.
          But if I render I got the second result Do I have to map the texture in any way?
          The IRender nxt rendered it on the fly without problem . (But not with the same quality though)
          V-Ray Version 01.05.30
            I'm very puzzled by this.
            Can you also post part of the model?
            • V Offline
              vintorix
              Ok, here is the model (9 MB).
              http://eu-se.com/su/vray_example.skp
                I don't know what it is. It worked fine for me. (See attached.)
                But I was using the latest VfSU - 1.48.68.
                Don't have 1.05.30 available right now to test.
                • soloS Offline
                  solo
                  Works fine on my side using 1.05.30
                  http://www.solos-art.com
                    o_O
                    hmm...
                    this is an odd one...
                    • soloS Offline
                      solo
                      Try switching off default lights in the global switches.
                      • V Offline
                        vintorix
                        I downloaded 1.48.68 and made a little progress. Now it looks like this!
                        Maybe it is time to read the manual? 😉
                        (I use ca 20 program and have to read them all. IRender nxt & Maxon both show acceptable result "out of the box" without having to tweak parameters. I rather spend my time with the Cinema 4D manual- thank you)
                        • V Offline
                          vintorix
                          Ok, now it works, and with rather good results as you can see. Thank you.
                          I wonder how many hours/days woúld I have wasted if I had not got help?
