    Un-Divide an Edge (Line)?
    10 Posts 6 Posters 1.3k Views 6 Watching
    • K
      Karash
      Is there anyway to "un-divide" an edge? I get this problem when using the follow me tool a lot. Afterwards, the edge it creates is broken up into itty bitty bits. Anyway to glue them back together?
      -Kar
      • Chris FullmerC
        If the line is actually linear, ten you can just draw out a small line segment from the break point and then delete. That will "heal" the line back into a single line. This will not work if it is not a truly linear line though.
        All my Plugins I've written
        • K
          Karash
          Yea, I had that work around going on straight lines, but I am needing a way to do curved lines after a "follow me" action. It is really slowing me down. The workaround is selecting bounding edges then deselecting what is not needed for the "route"...but sometimes that is not possible.
          • brookefoxB
            brookefox
            That does not seem to work for me Chris, whether I continue in the direction of the existing bits or change the angle of the next segment. I remembered there was an easy way.... (other than weld.rb (?)), but it is lost to me now.
            edit: Oh... draw the new segment from an internal break point...of course.
            ~ Brooke
            • EarthMoverE
              EarthMover
              You could always use the Weld plugin and see if that un-divides the lines. You also may want to look at Fredosix's plugin called Hover Select. It allows you to select all the lines of a curve even if they are divided.
              Content Creator at Skapeup
              • K
                Karash
                I will look into that Earthmover, thanks for the tip.
                brookefox, what do you mean by "draw the new segment from an internal break point" ?
                -Kar
                • GaieusG
                  Weld will only "weld" those edges (so you can select them as one entity) but will not remove the segmentation. There is a "repair broken lines" plugin that Jim is suggesting here:
                  http://forums.sketchucation.com/viewtopic.php?p=189740#p189740
                  But I cannot seem to be able to access the Ruby Library Depot ATM. This would indeed "heal" these divided edges.
                  • brookefoxB
                    brookefox
                    Draw from a break point away from the outer ends, not from an end end point (on a segment not attached to another at both ends, but rather at only one end).
                    ~ Brooke
                    • simon le bonS
                      simon le bon
                      Hi 😉
                      [flash=480,385:l7f79hxg]http://www.youtube.com/v/mSe8DkJ_5mE[/flash:l7f79hxg]
                      repair_broken_lines.rb
                      Re: It seems that Ruby Library Depot can be reached again... 😉
                      *simon
                      • GaieusG
                        *simon
                        Thanks Simon. It is actually on and off nowadays and sometimes it works sometimes don't.
