    Vray output issues
    renderpluginsextensions
    2 Posts 2 Posters 447 Views 2 Watching
    • A
      arjunmax09
      I'm trying to render a model that is an optical illusion ,,, but the moment i try to render it.....vray changes the view angle and spoils the optical illusion......checkout the attached file. I'm using Vray version 1.05.30. I have thomthom's selection toys installed but have no idea how to use it to get the desired output in this case....
      Arjun- optical illusion.skp
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • thomthomT
        You're using parallel perspective. VfSU doesn't work well with that. At least not with physical camera. I remember people talking about various ways to do this, but I don't know what they did. I never had to use parallel projections.
        The ASGVis forum should have a few posts on this.
