    Vray output issues
    renderpluginsextensions
    2 Posts 2 Posters 407 Views 2 Watching
      arjunmax09
      I'm trying to render a model that is an optical illusion ,,, but the moment i try to render it.....vray changes the view angle and spoils the optical illusion......checkout the attached file. I'm using Vray version 1.05.30. I have thomthom's selection toys installed but have no idea how to use it to get the desired output in this case....
      Arjun- optical illusion.skp
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
        You're using parallel perspective. VfSU doesn't work well with that. At least not with physical camera. I remember people talking about various ways to do this, but I don't know what they did. I never had to use parallel projections.
        The ASGVis forum should have a few posts on this.
