    Broken cardboard
    3 Posts 2 Posters 1.0k Views 2 Watching
    • R
      reymond
      hi all
      I need a 3d model from a broken cardboard.
      can someone help me this to modeling?
      Sketchup & Vray Trainer
      • TIGT
        Please explain a little more... πŸ˜•
        If you want to use the image as background use it within a Style and place your model on it.
        Or perhaps import the image, explode to face and make a hole in it so it's a 'flat' face.
        [Apply the texture to the back too?]
        Or it you want to physically model it in 3D cut the torn pieces and group the 'triangles' then rotate them in 3D dragging the rotate-protractor along a common fold/edge, so the rotation axis follows the line. Explode groups back together when you are done...
        • R
          reymond
          thank you for the your help.
          I solved the problem with a bump map.
