    Vray 1.05.30 Glass
    renderpluginsextensions
    4 Posts 2 Posters 1.0k Views 2 Watching
      rspierenburg
      Hi I was wondering if someone can help me. I'm looking at adding a bump map to a glass material I have. The problem is this, since the glass material has no actual texture (just straight color) there is no UV map to help dimension the bump map. I've tried adding a second diffuse layer with a texture and 100% transparency but that doesn't help as SU seems to only recognize the first diffuse map. Any other solutions? Oh and to top it off the glass is only 30% transparency (the client find real glass too dark).
      Rob
      SU 7
      Vray 1.05.30
        If there is no UV mapping then all maps will be 1"x1". That means if you set a map's Repeat value to 0.1 - then it'll be 10"x10".
        It will always be inches as that is the internal unit of Sketchup - regardless of your model units.
        That is one way of doing it.
        Add it as the first. Glass had a 100% diffuse anyway. The glass colour is set by the refraction layer.
        If you have a 2D glass and must use diffuse to tint your glass then add it as the second layer - which will then be visible under your 100% transparent main diffuse.
          rspierenburg
          Thanks, that worked perfectly. Good to know about the Vray texture size. You rock
            Every length unit in VfSU refer to inches. Displacement multiplier for instance 1.0 = 1 inch.
            Override focal distance - inches.
