    [Plugin] RayTrace & RaySpray
    46 Posts 23 Posters 77.5k Views 23 Watching
      @adamb said:
      In some sense, we've got this all back to front. We should be describing our models with the minimum information and then refine that description to get more details. Certainly when you get to the point of having sub-pixel polygons, you have to question whether this is such a great representation.
      hmm... a plugins to analyse the model from the current viewport and highlight the ones with many sub-pixel polygons... or is there one out there already?
      • kenK Offline
        ken
        OK, I can visualize it now, the TV detective pulls out his laptop, fires up Sketchup and the ray trace plugin, and determine the bullets fight path, and solves another crime, all thanks to TIG and his plugin.
        Ken
        • honoluludesktopH Offline
          honoluludesktop
          @adamb said:
          But thats the point. The wavelength of visible light is so small compared to the thickness of the mirror, the interference between the bounce from the back of the mirror and front is effectively zero.
          Unless you have very thin mirrors! πŸ™‚
          Sounds like I got it backwards πŸ™‚
          How about a render program that lets the user adjust select components (like keyboards in a large office) to reduce render times?
          • Didier BurD Offline
            Didier Bur
            Cool plugin TIG !
            I'll surely use it to explain to my students how light bounces when hiting objects and so on 😎
            I cannot see the usual red-green-black-blue-cyan colored dots when snapping points for postionning the start and end points. Is this normal ?
            DB
              @didier bur said:
              Cool plugin TIG !
              I'll surely use it to explain to my students how light bounces when hitting objects and so on 😎
              I cannot see the usual red-green-black-blue-cyan colored dots when snapping points for postioning the start and end points. Is this normal ?
              I have probably not set 'inferencing' properly in the tool code !
              I did it in a rush... πŸ˜’
              I'll look at it..........
                Didier Bur
                I give you 1 hour to correct the problem. And please DON'T GO TO SLEEP. HEAR ME ? 🀣
                DB
                • kenK Offline
                  ken
                  Thanks for a fun plugin. I know other will need this, and I know sometime in the future I will be able to find a good use for this plugin.
                  On a side note, my version just keep bouncing the ole rays until it doesn't hit anything. I was playing with it in a box. Selecting the "NO" bottom does not stop the rays.
                  Just passing this on. If I am the only one with this problem, I can live with it.
                  Again, thanks for plugin. Can't wait until I find some usual project for this plugin.
                  Ken
                    Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=235227#p235227
                    The bouncing now stops on 'No' - stupid typo πŸ˜’
                    Inferencing improved.
                    [Sorry it took so long - but I do have to eat etc... πŸ˜‰ ]
                    • H Offline
                      hebeijianke
                      thx
                      Can you make a icon for this plugin
                        lbjazz
                        Holy crap - THANK YOU! I've been needing something like this for a while but don't have the time to learn enough Ruby to make it happen. You ROCK!
                          lincol
                          I cannot find any link to this. It would be really handy to me for roughing up mirror lenses. Where is link
                            First post on the first page of this thread.
                              lincol
                              thanks - I didnt have proper access - something to do with new subscription
                              lin
                                mus257
                                This is really interesting. I look forward to sifting through the code.
                                As a sound and video designer, I can say this could be very handy. It does however have some issues for practical use as it stands.
                                When using spray, all sources must be assumed as omnidirectional. It would great to be able to show just a 50 degree spray and specify the focus. As it stands you have to show spray as "flat", i.e. no tilt in the XYZ axes. This prevents you from, say, angling a speaker down. I do use more advanced sound software like EASE for this normally, but I think Sketchup could work better for showing raytracing to a client than EASE.
                                In trace mode, it would be cool to be able to just show source and direction and the first reflection angle is calculated when it encounters a face. I have coverage angles I use in Sketchup and used them to illustrate. Right now, if I click on the origin, then the end of the coverage line, it calculates the reflection off the end of the line, not off the face it's aimed at.
                                Just some thoughts if you keep modifying the script. Thanks for the awesome work.
                                  mus257
                                  raytrace test.skprayspray test.skpThis is really interesting. I look forward to sifting through the code.
                                    mus257
                                    Hi TIG,
                                    I got back to playing with the rayspray last night and was using it for a noise study at my apartment. (We have a Kragen parking lot next to the patio.) 😞 Anyway, I tried using the spray and deleting coverage that wasn't helpful. Then I realized it was much easier to just put a dome over the spray and adjust that to coverage that I cared about. i.e., I'm not looking at the noise flying up into the sky. Worked pretty well, an example is attached. It's a great tool, thanks. Though if you ever figure out how to aim a controlled spray or, say, 2 rays with a specific degree spread between them, this would be even more powerful for sound and light coverage.
                                    Thanks again
                                    Joe
                                    Rayspray.skp
                                      Lobster
                                      Thanks Tig,
                                      Will be useful to me i am sure.
                                      Regards
                                      Sam
                                        In v8 the 'raytest' method is flaky and it is used by these tools... BUT a fix is promised for MR1...
                                        • F Offline
                                          flowheimer
                                          I just discovered RayTrace/Spray today; I was searching for a plugin with just this sort of functionality and this appears to be the only one of its kind.
                                          If I may offer some feedback:
                                          I'm using it in Sketchup 8.0.3117 and am encountering some odd behaviour.
                                          For some reason, using RayTrace, sometimes a ray will bounce, and sometimes it just stops short of the next plane, even within a fully enclosed volume. As far as I can tell there is no consistency to this behaviour and thus no telling how many bounces (if any) a ray will perform before abruptly terminating mid-flight.
                                          Any ideas?
                                            Does it happen in SU7?
                                            There is a bug in the raytracing function in SU8.
                                            • 2 / 3
