    [Plugin] RayTrace & RaySpray
    46 Posts 23 Posters 81.3k Views 23 Watching
      Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=235227#p235227
      The bouncing now stops on 'No' - stupid typo πŸ˜’
      Inferencing improved.
      [Sorry it took so long - but I do have to eat etc... πŸ˜‰ ]
      • H
        hebeijianke
        thx
        Can you make a icon for this plugin
        • L
          lbjazz
          Holy crap - THANK YOU! I've been needing something like this for a while but don't have the time to learn enough Ruby to make it happen. You ROCK!
          • L
            lincol
            I cannot find any link to this. It would be really handy to me for roughing up mirror lenses. Where is link
              First post on the first page of this thread.
              • L
                lincol
                thanks - I didnt have proper access - something to do with new subscription
                lin
                  mus257
                  This is really interesting. I look forward to sifting through the code.
                  As a sound and video designer, I can say this could be very handy. It does however have some issues for practical use as it stands.
                  When using spray, all sources must be assumed as omnidirectional. It would great to be able to show just a 50 degree spray and specify the focus. As it stands you have to show spray as "flat", i.e. no tilt in the XYZ axes. This prevents you from, say, angling a speaker down. I do use more advanced sound software like EASE for this normally, but I think Sketchup could work better for showing raytracing to a client than EASE.
                  In trace mode, it would be cool to be able to just show source and direction and the first reflection angle is calculated when it encounters a face. I have coverage angles I use in Sketchup and used them to illustrate. Right now, if I click on the origin, then the end of the coverage line, it calculates the reflection off the end of the line, not off the face it's aimed at.
                  Just some thoughts if you keep modifying the script. Thanks for the awesome work.
                    mus257
                    raytrace test.skprayspray test.skpThis is really interesting. I look forward to sifting through the code.
                      mus257
                      Hi TIG,
                      I got back to playing with the rayspray last night and was using it for a noise study at my apartment. (We have a Kragen parking lot next to the patio.) 😞 Anyway, I tried using the spray and deleting coverage that wasn't helpful. Then I realized it was much easier to just put a dome over the spray and adjust that to coverage that I cared about. i.e., I'm not looking at the noise flying up into the sky. Worked pretty well, an example is attached. It's a great tool, thanks. Though if you ever figure out how to aim a controlled spray or, say, 2 rays with a specific degree spread between them, this would be even more powerful for sound and light coverage.
                      Thanks again
                      Joe
                      Rayspray.skp
                      • L
                        Lobster
                        Thanks Tig,
                        Will be useful to me i am sure.
                        Regards
                        Sam
                          In v8 the 'raytest' method is flaky and it is used by these tools... BUT a fix is promised for MR1...
                          • F
                            flowheimer
                            I just discovered RayTrace/Spray today; I was searching for a plugin with just this sort of functionality and this appears to be the only one of its kind.
                            If I may offer some feedback:
                            I'm using it in Sketchup 8.0.3117 and am encountering some odd behaviour.
                            For some reason, using RayTrace, sometimes a ray will bounce, and sometimes it just stops short of the next plane, even within a fully enclosed volume. As far as I can tell there is no consistency to this behaviour and thus no telling how many bounces (if any) a ray will perform before abruptly terminating mid-flight.
                            Any ideas?
                              Does it happen in SU7?
                              There is a bug in the raytracing function in SU8.
                              • F
                                flowheimer
                                It seems to work in SU7.
                                Guess I'll use 7 till it works in 8.
                                fH
                                  An impending maintenance release for v8 might help with ray-tracing...
                                    mjm6x9
                                    This is just the plugin I've been looking for!
                                    I work for a dedicated acoustic consultancy firm and this is incredibly useful for small room acoustics projects.
                                    I've several ideas on improvements, but just want to know if you are going to be developing this further in the near future?
                                    Or what would be the possibility of buying the existing code from you and looking to develop it further ourselves??
                                    The things I'd like to see developed are:
                                    1. Specification of number of reflections in RaySpray (1st, 2nd, 3rd order etc)
                                    2. Different coloured lines to display reflection order (e.g. 1st reflection blue, 2nd reflection green)
                                    3. limit RaySpray to particular rotation angle, i.e. currently it runs through 360 degrees but could it be set to only run through 90 degrees)
                                    4. Would it be possibly to highlight the reflecting surface when using RayTrace in order to easily establish which surface you are reflecting off (this is difficult to visualise currently)
                                    5. Possible option of setting specific reflecting surface (maybe using Layers) so that reflections only occurred off these surfaces when using RaySpray
                                    Look forward to hearing from you
                                    • B
                                      BrooksL
                                      Wow TIG - I've been looking all over for a tool like this for a couple weeks! [I avoided the keywords ray trace because it turns up lots of results for rendering]
                                      I need such to tool to look at angles of reflection and reflected angles for laser beam vision systems with mirrors - because figuring the angles manually can get quite tedious! Thanks!
                                      A few bug/issues I'm finding with V1.2 20100326 - using in SketchUp 8 Pro 8.0.11752 -
                                      Sometimes a ray will not reflect; the second point selection was an intersection of guidelines on a plane, but it wasn't reflecting from that point until I deleted the existing guides and guidepoints in that area and re-drew them (the original guides and points were indeed on the plane).
                                      I don't see the magenta preview ray.
                                      Seems to use a lot of CPU resources to during point selection - noticeable lag in following the mouse, but maybe that's just the SketchUp api.
                                      With RaySpray;
                                      The cursor inference point indicator is not showing up.
                                      Some of the rays do reflect -- and stop when they hit an original sprayed ray -- and original rays stop when they hit a reflected ray. (sample file attached)
                                      Still, this is a REALLY helpful plugin! Thanks, TIG!
                                      [to help others find these helpful plugins, some additional keywords: Reflected Angle, Reflected Ray, Angle of Reflection, Beam Reflection, Beam Reflect, Reflection Guide ]
                                      RaySpray V1.2 erratic in SketchUp 8.0.11752
                                      • L
                                        lydfa
                                        Great plugin!
                                        Thank you very much.
                                        Cheers,
                                        Dennis
                                        • Z
                                          zlitalien
                                          TIG, this has been a great tool to use! I'm wondering if there's a way to make the ray auto adjust in real time if you move the object its reflecting off of?
                                          • 2 / 3
