    [Plugin] RayTrace & RaySpray
    46 Posts 23 Posters 81.3k Views 23 Watching
    • Didier BurD
      Didier Bur
      Cool plugin TIG !
      I'll surely use it to explain to my students how light bounces when hiting objects and so on 😎
      I cannot see the usual red-green-black-blue-cyan colored dots when snapping points for postionning the start and end points. Is this normal ?
      DB
        @didier bur said:
        Cool plugin TIG !
        I'll surely use it to explain to my students how light bounces when hitting objects and so on 😎
        I cannot see the usual red-green-black-blue-cyan colored dots when snapping points for postioning the start and end points. Is this normal ?
        I have probably not set 'inferencing' properly in the tool code !
        I did it in a rush... πŸ˜’
        I'll look at it..........
        • Didier BurD
          Didier Bur
          I give you 1 hour to correct the problem. And please DON'T GO TO SLEEP. HEAR ME ? 🀣
          DB
          • kenK
            ken
            Thanks for a fun plugin. I know other will need this, and I know sometime in the future I will be able to find a good use for this plugin.
            On a side note, my version just keep bouncing the ole rays until it doesn't hit anything. I was playing with it in a box. Selecting the "NO" bottom does not stop the rays.
            Just passing this on. If I am the only one with this problem, I can live with it.
            Again, thanks for plugin. Can't wait until I find some usual project for this plugin.
            Ken
              Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=235227#p235227
              The bouncing now stops on 'No' - stupid typo πŸ˜’
              Inferencing improved.
              [Sorry it took so long - but I do have to eat etc... πŸ˜‰ ]
              • H
                hebeijianke
                thx
                Can you make a icon for this plugin
                • L
                  lbjazz
                  Holy crap - THANK YOU! I've been needing something like this for a while but don't have the time to learn enough Ruby to make it happen. You ROCK!
                  • L
                    lincol
                    I cannot find any link to this. It would be really handy to me for roughing up mirror lenses. Where is link
                      First post on the first page of this thread.
                      • L
                        lincol
                        thanks - I didnt have proper access - something to do with new subscription
                        lin
                          mus257
                          This is really interesting. I look forward to sifting through the code.
                          As a sound and video designer, I can say this could be very handy. It does however have some issues for practical use as it stands.
                          When using spray, all sources must be assumed as omnidirectional. It would great to be able to show just a 50 degree spray and specify the focus. As it stands you have to show spray as "flat", i.e. no tilt in the XYZ axes. This prevents you from, say, angling a speaker down. I do use more advanced sound software like EASE for this normally, but I think Sketchup could work better for showing raytracing to a client than EASE.
                          In trace mode, it would be cool to be able to just show source and direction and the first reflection angle is calculated when it encounters a face. I have coverage angles I use in Sketchup and used them to illustrate. Right now, if I click on the origin, then the end of the coverage line, it calculates the reflection off the end of the line, not off the face it's aimed at.
                          Just some thoughts if you keep modifying the script. Thanks for the awesome work.
                            mus257
                            raytrace test.skprayspray test.skpThis is really interesting. I look forward to sifting through the code.
                              mus257
                              Hi TIG,
                              I got back to playing with the rayspray last night and was using it for a noise study at my apartment. (We have a Kragen parking lot next to the patio.) 😞 Anyway, I tried using the spray and deleting coverage that wasn't helpful. Then I realized it was much easier to just put a dome over the spray and adjust that to coverage that I cared about. i.e., I'm not looking at the noise flying up into the sky. Worked pretty well, an example is attached. It's a great tool, thanks. Though if you ever figure out how to aim a controlled spray or, say, 2 rays with a specific degree spread between them, this would be even more powerful for sound and light coverage.
                              Thanks again
                              Joe
                              Rayspray.skp
                              • L
                                Lobster
                                Thanks Tig,
                                Will be useful to me i am sure.
                                Regards
                                Sam
                                  In v8 the 'raytest' method is flaky and it is used by these tools... BUT a fix is promised for MR1...
                                  • F
                                    flowheimer
                                    I just discovered RayTrace/Spray today; I was searching for a plugin with just this sort of functionality and this appears to be the only one of its kind.
                                    If I may offer some feedback:
                                    I'm using it in Sketchup 8.0.3117 and am encountering some odd behaviour.
                                    For some reason, using RayTrace, sometimes a ray will bounce, and sometimes it just stops short of the next plane, even within a fully enclosed volume. As far as I can tell there is no consistency to this behaviour and thus no telling how many bounces (if any) a ray will perform before abruptly terminating mid-flight.
                                    Any ideas?
                                      Does it happen in SU7?
                                      There is a bug in the raytracing function in SU8.
                                      • F
                                        flowheimer
                                        It seems to work in SU7.
                                        Guess I'll use 7 till it works in 8.
                                        fH
                                          An impending maintenance release for v8 might help with ray-tracing...
                                            mjm6x9
                                            This is just the plugin I've been looking for!
                                            I work for a dedicated acoustic consultancy firm and this is incredibly useful for small room acoustics projects.
                                            I've several ideas on improvements, but just want to know if you are going to be developing this further in the near future?
                                            Or what would be the possibility of buying the existing code from you and looking to develop it further ourselves??
                                            The things I'd like to see developed are:
                                            1. Specification of number of reflections in RaySpray (1st, 2nd, 3rd order etc)
                                            2. Different coloured lines to display reflection order (e.g. 1st reflection blue, 2nd reflection green)
                                            3. limit RaySpray to particular rotation angle, i.e. currently it runs through 360 degrees but could it be set to only run through 90 degrees)
                                            4. Would it be possibly to highlight the reflecting surface when using RayTrace in order to easily establish which surface you are reflecting off (this is difficult to visualise currently)
                                            5. Possible option of setting specific reflecting surface (maybe using Layers) so that reflections only occurred off these surfaces when using RaySpray
                                            Look forward to hearing from you
                                            • 2 / 3
