    Window components
    5 Posts 3 Posters 1.0k Views 3 Watching
    • K Offline
      kat
      Hello,
      I'm working on a script to get information about the windows a user placed in his Sketchup model.
      To do so, I'v made some window models and placed them into the 'Components' folder.
      With a Ruby script, I attach the information about the windows by using attributes. Now, I also want my windows to cut a hole in the wall they are placed into, but this doesn't really work.
      I've tried to change the behavior of the componentdefinition of my windows with this code:
      componentdef = Sketchup.active_model.definitions.load path
      componentdef.behavior.snapto = SnapTo_Vertical
      componentdef.behavior.cuts_opening = true
      But when a user now places an instance of the window component in his model, nothing happens, the wall stays intact and no hole is cut out. I think the component isn't really glued to the face because when i ask all the faces in the model whether they have a component glued to with get_glued_instances, nil is returned.
      Is my approach to simplistic? Or does anyone know what I am doing wrong?
      Thanks a lot for any help
        Behavior.is2d=
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/behavior.html#is2d=
        The is2d= method is used to set the 2D behavior for a component: whether it can be glued or aligned to a face.
        • K Offline
          kat
          Hey,
          Thanks a lot for your help last time, I've changed my script a bit, but unfortunally, it still doesn't work.
          The component doesn't cut a hole in the face it is placed into and it is not placed on the right layer.
          I really can't see what is wrong. I am sending you the entire method I wrote to load the window components placed in the components folder into the SU model.
          def laad_componenten
          # Define correct path for the csv information file
          windowcomponents = File.join($components,"Ramen","*.csv")
          files = Dir.glob(windowcomponents)
          # String loaded components
          @loaded_comp = " "
          # Look for the windows
            files.each { |file|
          	  f = File.open(file,"r")
          	f.each {|line| line.to_s
          			    @data  = line.split(';').each { |string| string.strip}
          	name = @data[0].to_s
          	# Define the path of the SU window
          	path = File.join($components,"Ramen", name+".skp")
          	# Load the component into the current model
                  # Attatch csv information to component using attributes
          	componentdef.set_attribute "info", "naam", naam.to_s
          	componentdef.set_attribute "info", "diktes", @data[1]
          	componentdef.set_attribute "info", "U-waarde", @data[2]
          	componentdef.set_attribute "info", "g-waarde", @data[3]
          	componentdef.set_attribute "info", "kostprijs", @data[4]
          	componentdef.visible = true
          	componentdef.behavior.is2d = true
          	# Put component on the right layer
          	windowlayer = $model.layers.at("Ramen")
          	componentdef.layer = windowlayer
          	# Name of loade component in string
          	@loaded_comp = @loaded_comp+naam+" ;"
          	f.close
          } end
          @loaded_comp.chop!
          UI.messagebox "All windows components loaded;"+@loaded_comp
          Hopefully you can help me
          thanks
            Did you make the component so it is 'flat' in 3D so that its "up" axis is Y/green ?
            OR at least when you 'made' it set its axes thus...
            Then it will cut a hole at its Z=0 plane on any face it is glued_to/cuts/is_2d ...
            • K Offline
              kat
              yes, it works!
              I made my windows in the SU components folder in the upright position,
              should have done it in the horizontal plane...
              thanks a lot tig!!!
