Copying Holes?
@newnoob said:
Do I have to live with that or is there a fix?
There is no fix, sadly it's by design. What you can do is a hole cutting component on each side of your volume...
OR... use my tool http://sketchucation.com/pluginstore?pln=HolePunchTool
to add associated reveal geometry to a hole-cutting component... -
Ok thanks for the information - at least I know now it is not my fault which is usually the case.
to add associated reveal geometry to a hole-cutting component...I'll check that out.
Register LoginAdvertisement
