Does anyone have a split face CMU texture ?
 I need a split face CMU texture for a small project. If anyone has one, or can point me in the right direction to look, I would sure appreciate it. Thanks
 I am assuming you have checked in cgtextures.com? EDIT: I just did a quick check and keyword search, and did not see that specific texture.
 What is the process to create one?EDIT again: See this thread: http://forums.sketchucation.com/viewtopic.php?f=40&t=26092#p224838. I did not have time to look. May be something there for you.
 Yes I did check out the CG site. Looked promising but the links are broken. I would make a texture if I could get a good high res image, but most images I have found aren't suitable. I'll keep looking.
 hey dale
 check out Acme Brick Masonry Designer program (free). It allows you to chose brick/cmu patterns and even create mixes of cmu/brick patterns. Hope that helps.
 Perfect, Thanks a lot.
 What would be acceptable resolution? Would this degrade in the process of creating the texture?
 @mitcorb said: What would be acceptable resolution? Would this degrade in the process of creating the texture? With a texture like this, it should be fairly easy to tile, because of its repetition, and the fact you could seam on a mortar line.
 Even though I use photoshop, I still prefer as face on an image as I can get, with as large a sample as possible of the material.
 No you shouldn't get degrading, particularly if you work in png format, even if you want to end up as a jpeg.
 I'm not a real expert on this, and I know there is a lot of software out there now that makes creating tileable textures really simple, but I have found most of them to be PC based, and mostly I work on a mac.
 There is a great tutorial @ http://www.youtube.com/watch?v=kjB7lYXqYFE.
 Belden Brick also has a free "online" tool for bricks & another for pavers. Works great with lots of mortar options. Wish I could find the same for floor & wall tiles!
 Here's another one. It's seamless. Diffuse, normal and specular maps. If you need higher resolution just tell me
 Thank you. That resolution will work great, and the mapping is perfect.
