    Double material editor
    4 Posts 3 Posters 331 Views 3 Watching
    • O Offline
      ozzidora
      I've the material editor like the attached image.
      Why must it be double? Is it right?
      thank
        If you look at the top right corner of the Material Browser dialog there is a toggle button - yours is showing a '-', if you click it the second lower pane will 'rollup' and disappear - the button then becomes a '+', you click that to get the second lower pane back again - it's a 'toggle'.
        The optional second pane is found in several of SUp's browsers and is there to help you manipulate collections of materials [in this case] between folders/the model etc... However, it is usually left rolled-up πŸ˜•
        • O Offline
          ozzidora
          than you, sometimes Ithink I'm little s....d
            It is a handy thing sometimes as you can easily drag and drop materials from one window to the other (say when you have just made a new material of an imported image from scratch and want to keep it in one of your libraries)
