    Renderproblem
    renderpluginsextensions
    11 Posts 4 Posters 1.9k Views 4 Watching
    • F Offline
      fbo_bern
      hi all
      its again the noob πŸ˜„
      why does the rendering plants from the plant collection so bad like this?
      thanks for help!
      fbo
        In the current version of VfSU - it does not read the alpha channel of images. You need to extract the alpha channel as a grayscale image and load it into the transparency slot in the diffuse layer.
        But next week VfSU is updated - then you'll only need to tick a checkbox to make it use the alpha channel.
        • F Offline
          fbo_bern
          okey, okey. i have the alpha image. but how i load this pic in the transparency slot of the diffuse layer? πŸ˜• πŸ˜• πŸ˜•
            • F Offline
              fbo_bern
              hey thomthom
              thanks for the manual.
              but it doesnt work by me.
              1. i open a clean su file.
              2. i import the plant.skp
              3. first render looks like this:
              4. i open the vray material editor. i put the alpha-png from the plant like your tutorial in the transparency diffuse layer.
              5. i render the same again
              im so sorry, but i realy dont understand, why this doesnt work...
              • F Offline
                fbo_bern
                ROFL, i found the problem. omg. sorry.... πŸ˜„
                I had a wrong alpha Picture. i must in the material editor " invers" and then " invers alpha" activate. then it functions. Thanks for the assistance.
                 :heart_eyes:
                  πŸ‘
                  Yes - V-Ray treat alpha images in such a way that white is 100% transparent and black is 0%.
                    Jessica S
                    is there something similar in Kerkythea??
                    @thomthom said:
                    [attachment=0:2gewb84w]<!-- ia0 -->alpha.png<!-- ia0 -->[/attachment:2gewb84w]
                      Jessica S
                      is there something similar in Kerkythea? 😞
                        Hi Jesica,
                        Yes, Kerky will automatically use the png transparency as clipmap. If there is no transparency in the image, you can manually load a clipmap like above.
                          Jessica S
                          Thx u so much!! This will help me a lot in the future!
